"Error in command line"
    HKEY is in registry, that means you press on Start -> Run (or just Windows key and R) -> Regedit
    You get the error when you check for Windows updates? If yes, then something is very wrong with your Vista.
      oh what should i do?
        If something is wrong with your Vista, as Blazkowicz said, you should reinstall your OS.
          try this:
          run daemon.exe as admin -> right click tray icon -> click preferences -> click integration -> select all -> check "Mount on first empty device" -> Apply and close daemon
          try automouting an iso or something
            hey i got the same problem today but i found out that daemon tools was installed in the wrong directory instead of C://programfilesx86/daemon tools it must bee set on C://Programfiles/daemon tools
            PROGRAM FILES INSTEAD OF PROGRAMFILES x86
            i hope this is the answer for you too
