Showing results 1 to 2 of 2
Thread: MDS Files, Viewer and DT command-line tools
    Default MDS Files, Viewer and DT command-line tools
    I'm searching a command-line tool which creates
    *.mds files (Media Descriptor Image Files) to a given
    *.iso image. Similar like the ImgBurn can do this with
    the GUI, but would be nice to have a command-line tool,
    which I can use in batch-files.
    Can DT 4.3x.x do theese kind of tasks from the
    command-line? Would be nice if the coders implement
    such a function.
    btw: Is the coder of the MDS-Viewer still active?
    Perhaps he would like to implement such a command-line
    function in the mds Viewer or tell us something about
    the mds-file structure...
    Stonehenge
    Quote Originally Posted by stonehenge View Post
    *.iso image.
    Image convertor is only available in DT Pro Advanced. But so far no command line switches, maybe the Devs will add them. So you will not see a convertor in DT Lite.
    Coder should still be active, but i don't know for sure.
    BTW you don't have really an effort of using mds viewer; i don't think the coder will be implement command line switches if he is still active.
