Showing results 1 to 6 of 6
Thread: problem with yasu
    Default problem with yasu
    I used dt4.12 and yasu1.4 ,and it worked well.
    But when I upgraded to dt4.30.1 and played my game as usauall , it said
    SecuROM&153; has determined that the tool 'YASU' is running in the background. Please deactivate and close this tool before you start the application.
    Then I installed dt4.30.1 and yasu 1.4 on my another computer , it WORK WELL with the same game.
    I wonder what may result in this problem?
    regards
    Maybe some remains of old version.
    Anyway, YASU is not needed for SecuROM games.
    Default Try this procedure please...
    Hi all!
    1. Blazkowicz I am not OK about your sentence (remark?), cause you wrote "Anyway, YASU is not needed for SecuROM games".
    For example for the game "World in conflict" with the last patch, if you mount its image in DT virtual reader without yasu, the game does not run.
    But if you run yasu with cloak option "securom" the game runs fine.
    2. Now for you "Fantasy 2001", try this procedure :
    a. Uninstall DT and yasu.
    b. Reboot your PC.
    c. Clean your Pc's register base with Ccleaner (it's free, no money) .
    d. Reboot your Pc again.
    e. Install again the last version of Daemon tools.
    f. Install yasu last version again.Be sure you put before yasu.exe in DT's file.
    g. Reboot your PC.
    3. If your game's image is welldone (good), your game would run fine with DT, for that do :
    a. Mount your game's image in DT's virtual reader.
    b. Click on Yasu's shortcut.
    c. Cloak (securom).
    d. Play your game.
    4. Please give the name of your game, and verify also (if you patched your game) if Dt or yasu are not blacklisted.
    Best regard and cordialy and sorry for my special English cause it is not my first language.
    joeldecaroual
    PS: This procedure is also OK on Vista 32 bits (if by hazard your Pc's OS is Vista).
    Well, i was talking about DT blacklist and there YASU is not needed. I was not talking about general SCSI blacklist which also affects other virtual drive software.
    I do have the latest SecuROM and working without special tools.
    Also YASU is outdated.
    hi. i really need help i used YASU to run PURE. then i found out it ran slowly on my pc. and when i was trying to install another game the cd/dvd drives wasnt there.
    someone who knows what to do??
    the pc i use is for school use so im pretty screwed there.
  6. #6
    Which dvd drives werent there? Physical or virtual ones?
