Showing results 21 to 30 of 41
Thread: Blindwrite Image does not work
  1. #21
    All located on a ide hdd.
    Itґs nice to be a Preiss but itґs higher to be a Bayer
  2. #22
    Tested one of your images on DT Lite and Pro - mounting is fine and i could also run Autorun.
    Maybe some path problems - your image path doesn't contain any special character?
    BTW which OS are you running?
    OS is Windows XP Prof. SP3
    No, the image path doesn`t contain special characters.
    If it is running fine at your side, where could be my problem?
    Other image formats like .iso e.g. are mounting, but with bw images the virtual drive tray keeps open and i cannot close it.
    That seems to be (one of) the problem(s).
    I have new installed d-tools also.
    Larry
  4. #24
    Did you try to open the image file or did you only mount it?
  5. #25
    I ran autorun and also browsed the CD.
    So what can i do?
    Any ideas or suggestions.
    Because the most of my images are bw5 or bw6 but i can't mount and use it, D-Tools is for me quite useless.
    Larry
  7. #27
    Whatґs up? Is this the end of the support? What can i do to mount this damned images?
    Any hints or tips are welcome.
    Larry
  8. #28
    Customer Terramex's Avatar
    06.09.2004
    2,566
    Quote Originally Posted by Larry Brent View Post
    Are there other (non-Blindwrite) images in the same path which mount fine ?
    Have you recently moved the BW images from another location ?
    Would you please try to recreate one of the images with Blindwrite and check whether that works then.
    If you're a Pro Advanced customer:
    When converting a Blindwrite image to MDS format; does that mount fine ?
  9. #29
    Thx for your replay.
    1. Yes there are other non - BW images in the same path and all of them working fine.
    2. No
    3. I have created recently with the newest BW version an image (what i have sent to Blazkowicz).
    This image does also not work.
    4. Converting does also not work correctly.
    Starts to convert but at the end there is only an error message. The converted mds file is not readable, says it contains no data.
    Larry
  10. #30
    Can you please redownload setup and reinstall and check again then.
    Could you tell us hash value of your imgengine.dll file?
    EDIT: Converter error reproduced, but mounting is still fine here. Converter issue is already resolved in next unleashed version.
