How copy game protected with Securom 07.37.0007 ?
    @Blazkowicz
    I assume you used New SecuROM profile. Which error do you get?
    You answered in the 2. Post New SecuROM Profile by using Alcohol. But Lego Indiana Jones is a DVD. In Alcohol you canґt have New Securom with a protected DVD. There is only a Profile Securom with DVD. Is that correct?
    Setternixe
      Yes, that is correct.
        But I have problems with that profile. At 55% it stops and the message is: "canґt get DPM of second Layer of DVD". So what can I do?
        Thanks for help!
        Setternixe
          Using latest Alcohol version? Which drive? Is it PTP or OTP?
            It is the latest Alcohol 1.9.8.7117. Drives are LG H30, LG H50and two external LG-Drives lg 5120 and the very new one LG BE-06LU. I donґt know, what you mean with PTP or OTP.
              This is almost the same experience I have with my GTA IV. The DVD is protected by more or less similar version of Securom.
              We were using the same version of Alcohol but mine is 52% FE but now I am using a much later build.
              1.9.7507
              It seems that this version is a tough one eh.
