Showing results 1 to 3 of 3
Thread: DT4.301 and Vista 64
    27.09.2008
    4
    Default DT4.301 and Vista 64
    After installing DT in my Vista 64 Ultimate, I get the following error after rebooting.
    Initialization error 0. This program requires at least Windows 2000 with SPTD or higher. Kernal debugger must be deactivated
    I have tried uninstalling DT and manually installing SPTD 1.56 again. But now I get a new error that says this:
    Internal setup error. Error code: 14. Contact Support.
    I tried cleaning the registry of all DT related and it hasn't helped.
    I really need some help here
    You disabled your security software (e. g. kaspersky, windows defender ...)?
    27.09.2008
    4
    I replied to your post in another thread I started on this thing. I missed the info concerning my thread being visible AFTER being approved by a moderator, so I posted a 2nd thread.
    Apologies for that.
    I managed to reinstall the software by disabling my Spyware Doctor.
    Vista is blocking Daemon when windows is started, so I have to manually launch it everytime. That I can live with though.
    As long as it works
