BSOD on image create
    If I have the check box "Ignore bad blocks" checked it get the BSOD.
    If it's not checked just the error message.
    What does the subchannel do?
    Thanks
    Mozy
      @mozy
      Do you have the chance to cross-check with another drive to see whether your
      drive is the culprit - respectively your drive in combination with DT Pro.
      AFAIR there were problems with recent ASUS drives before.
      Maybe also of help to pinpoint the problem:
      Try whether it behaves the same when creating image with Alcohol 52%.
        I've done some more testing and here is what happens:
        • No subChannel settings (ie none) and "ignore bad blocks" unchecked => Disk imaging failed error
        • Any subChannel setting or "ignore bad blocks" checked => BSOD
        I'm not overheating, cpu and gpu temperatures are all good.
        Unfortunately I don't have another option for my DVD/CD drive. My system is one I built a couple of years ago. Looks like I have another reason to lobby for a new system.
        IMHH, I think there is some issue that is hardware related. I simply can't afford to get another drive to test with right now.
        I can't get my system to blue screen in any other scenario.
        Thanks again for all of your help.
        mozy
