mounted image prob
  • mounted image prob
    hi
    i need some please im running V4.08 and have not had a problem up till now
    ive been trying to install a game,unbeknown to me at the time i was missing out a step.i was able to install but couldnt play due to missing the step.
    ive uninstalled everything,cleared everything to do with the game,reinstalled daemon tools.
    when i come to remount image (to start reinstall)i only have options to play,uninstall ...ect.nothing happens when i click on uninstall either.
    how do i get daemon tools to allow me to install?
    THANKS
    Which step you missed? Could you post the instruction you meant?
      the step i missed was, if the game didnt run i had to unmount main image and remount a smaller image in another file then run game
        And where have you got that instruction from?
        Also how you created your image?
          ??? my mate told me,the readme file was quite vague
