Internal Setup Error. Error Code: 256. Contact Support
  • #31
    I have the same problem.
    Yesterday i just reinstal my windows sp3 and instaled daemon tools lite, it worked perfectly, i dont know if K-lite mega codec pack can be the reason for this problem, because before i install these drivers i dont have a problem with daemon tools?!?
    • #32
      Same problem here,don't try to hide it under "security software" thing-FIX IT!And also DAEMON Tools Network Edition - since when?
      • #33
        It is not a DT issue when security software is trying to modify our code.
        • #34
          Hi frioux,
          I had the same problem that you, running VirtualBox with Windows 7 32-bits, I found in virtualbox forum that your CPU needs to support Virtualization. I needed to enable the Virtualization in BIOS, and Daemon installed without any problems.
          I have a AMD Phenom II X4 .
          Regards
          • #35
            Same problem as above, only I am using Ubuntu 10.4 as my os.
            any suggestions?
            • #36
              Enable virtualization as it was noticed above.
              • #37
                Same Problem
                Originally Posted by Blazkowicz View Post
                Will try to get that version and will try it later.
                Which OS do you have?
                Using Microsoft Security Essentials
                i5-4570 LGA1150
