Showing results 1 to 7 of 7
Thread: Installation bug in Daemon Tools Lite 4.30.2
    Default Installation bug in Daemon Tools Lite 4.30.2
    Hello, I am a new comer of DT forum.
    Just want to report a bug.
    After I choose Traditional Chinese in installation wizard and press "next", the installation program will crash.
    I have tried 2 different PC but this problem still happen.
    * Both PC are using WinXP SP3 Traditional Chinese.
    Hope this will be fixed in next build.
    14.12.2008
    2
    The same thing happened in the winxp sp3 simplified Chinese.
    I've compared the MD5 and it matched.
    Not only is WinXP SP3,
    I have 2 computers, Vista x64 and Win2003 x32.
    The same thing happened in all.
    @aprilfishi
    OS is also a chinese one? I can't reproduce it when selecting Chinese in setup in an English XP.
    14.12.2008
    2
    That also happens in Vista 32bit Chinese Simplified.
    And this time, i've confirmed that if I select English in the installation, it will be setup perfectly.
    And I can change the language to Chinese Simplified in the "preferences" and it works well.
  6. #6
    yes, os is simplified chinese.
  7. #7
    Bad code was found.
    Attached Thumbnails Attached Thumbnails Click image for larger version
ID:	673   Click image for larger version
    享受您的身体 利用您的脑壳
