Page 10 of 19 FirstFirst ... 89101112 ... LastLast
Showing results 91 to 100 of 181
  1. #91
    28.03.2009
    10
    mine are:
    836e42a2
    4ebb3dae128424c8c664430b80aa8f7e
  2. #92
    Since hash differs, that error comes up. Did you download it from here (attachment)? If yes, archive is fine, try with another browser and no download manager to redownload it. And if you have done that and still not working, check your ram for errors.
    I can only get this far, won't let me cloak it.
  4. #94
    28.03.2009
    10
    i downloaded it with IExplorer and it works fine thanks.
  5. #95
    28.03.2009
    10
    A new problem appears when i launch it from IExplorer "Open" after download it works but when i launch it from DTPro folder it doesn't work.
  6. #96
    Default No luck for me with DTE
    I'm really frustrated at this point. I've tried just about everything I've read here to no avail.
    Windows XP SP3
    DT 4.30.0304 Pro Advanced
    DTE-2.2.10.0 (Hash checked good)
    Norton Endpoint 11 - Disabled for testing
    DTE Crashes immediately...no other ISO program running. Good MDS image created from disk.
    Also playing Wanted.
  7. #97
    Hi,
    I know that DT Lite can't add a new vIDE drive but I want to ask you all if there is a way to do this by modifing the registry
    Thanks
  8. #98
    Quote Originally Posted by Forsakenfire View Post
    You have to extract it to install folder of DT Pro as DTE is stating.
    @RazzoCotto
    It is not possible to do that through registry.
    @SLAYER991
    They must not be runned (other iso programmes), they only have to be installed with a virtual drive.
    @rakyhhh
    And which error you get in DT Pro folder?
    28.03.2009
    10
    that:
    ImageShack - Image Hosting :: 64719881.png
    and DTE doesn't work with IExplorer again ...
  10. #100
    Hi everyone !
    Thanks for this wonderful thread. But I still have a problem with my DTE.
    I paste it on my DT pro installation folder (C:\Program Files\DAEMON Tools Pro) but it still have the "Make sure you copy DTE to installation folder" red message.
    Also, my drive is an IDE, but I can't cloak it : "SecuROM cloack status : Unable to cloack this drive".
    Can someone have an idea of my problem?
    Thanks !
    Screen :
