Can u help me? my DTE doesn't work.. I did everything right, but DTE doesn't work anyway..
@artozas
If you would like to provide more information (check this thread for information) and what is exactly not working?
Can I find somewhere an older version as this one doesn't support win2k? Thanks.
If current one isn't working, then older version are also not working.
Hi i am having a problem with this, i am trying to run Fallout 3 but i keep getting problems with the SecuROM.
The image here is my best effort to try and help as i dnt rly know alot about images and mounting etc...
I will be happy to provide more information on request as i want to get past this problem!
Note: OS is Vista 32 bit Home.
Ive restarted, the image file was done with a SecuROm profile at max speed i believe. The DTE is in the same program files location as Daemon Tools.
Many thanks
hello i have a problem with the extension tool
Anyway I downloaded exact same version you said and the DTE you posted in 1st thread.Than i created IDE drive and changed parameters the problem is the virtual disk is not showing in DTE!
any suggestions?
http://www.shrani.si/f/1R/bk/3F1BlDAI/omg.jpg
Hello, sorry for my bad english.
I have daemon tools advanced version shareware 4.30.0305.0077.
I have the quadcore with 4gb with windows vista with SP1 and internet explorer 8.
I have installed the daemon tools extension (dte.exe file) v.2.2.10.0 in the root directory of daemon tools.
When I click on the dte.exe files, to appear a screen, but after few seconds this screen crashed (DT not crashed).
What is the problem?
Thank you for the next answer!
Giulio
@orsa99
DTE is not a tool from DT, therefore i moved your post here.
The crash can be related to either a virtual drive by Ultra/Magic/PowerISO or too much virtual/physical drives (more than 13).
Therefore deactivate virtual drive by mentioned programes or lower virtual/physical drives amount in DT Pro.
Or just use Y.A.S.U
Mail:
curerom @ daemon-tools.cc
