Page 15 of 19 FirstFirst ... 51314151617 ... LastLast
Showing results 141 to 150 of 181
  1. #141
    @bullet21tt
    We already "gave" you a working DTE, just other software or yours are interferring.
    Is there any plans to make DTE compatible with Windows 7? If so, is there an ETA?
  3. #143
    I heard from author he is already working on Win 7 and as usual he can't tell any ETA.
    Glad to hear, thanks. Hopefully it comes soon.
  5. #145
    helo i got an error when trying to cloak my mdf well i open dte and then says
    safedisc:this device can be cloaked
    securom:cloaking not allowed
    can u tell me wich emulations should i have open?
    i tried some conbinations of emulation on/off and it didnt work
    i use vista+latest dt pr0 advanced +latest dte
    and the game im trying to cloak is star wars jedi force unleashed
  6. #146
    You don't need emulation options.
    Also you need to cloak SecuROM for vIDE.
    Also which DTE version are you running?
    im using dte 3.0.15.0 should i use yasu to cloak securom?
    because when i try to cloak it it says cloacking not allowed in securom section has one red circle(in dte)im wondering what im doing wrong
  8. #148
    Also i told you you need to cloak vIDE, not vSCSI.
    ok i tried to cloak vIDE but it says emulation detected
    could u please link me the version u said that works with dte cuz i cant find it all over the net has newer versions
  10. #150
    3.1.19.0:
    USB driver code rewritten and updated
    USB driver signed now
    Windows 7 USB driver support added
    USB driver state remembered
    vUSB drive properties added
    Disk-Tools.com - Published Software Download
    Note: possible BSODs when following things are happening: source drive is deleting, SCSI adapter stopping or USB uses non-MS drivers
    If you get any BSOD (Blue Screen of Death), please upload latest minidump available from c:\windows\minidump folder (c: could be also another drive letter, depends on Windows install drive).
    If you get any other error than a BSOD, describe your steps precisely.
