Page 17 of 19 FirstFirst ... 71516171819 LastLast
Showing results 161 to 170 of 181
  1. #161
    Reef's Avatar
    30.03.2003
    860
    Seriously, this is way too much of a hassle only to play a game. It has come to the point that it is actually a lot easier to just insert the original disc and play the game.
    My days of buying retail games are over. Most games are also released on Steam nowadays, which is a lot easier than messing around with some anti-blacklisting tool and hoping it won't BSOD.
    I know games on Steam are usually quite expensive, but this price also includes keeping my games up-to-date automatically
  2. #162
    Quote Originally Posted by Reef View Post
    Couldn't agree more but it's only needed for a very short time before a gamefix comes out.
  3. #163
    Doing 4 clicks is not complicated.
    Reef's Avatar
    30.03.2003
    860
    I challenge DT Soft to put that DTE 'manual' on disc-soft.com, so people can see what they will need to do to be able to run their games with DT Pro. Since it's 'not complicated', it should be no problem
  5. #165
    Default Which version?
    Are there any versions other then the one listed in the OP that work with both Win7 x64 and DTE?
    I have recently purchased DT for use with DTE and found the latest version of DT does not seem to be recognised by DTE......and when I try to install the version listed in the OP it crashes during the file copy stage of setup with an event that specifies DT is not compatible "with this version of Windows".
    TIA
  6. #166
    3.3.29.0:
    - Code update for vUSB driver
    - Device attach problem fixed
    - ProtectDisc partially support
    - StarForce protection support (newest DT is required)
    - Registry jumps in drive properties are added
    - Virtual device properties are extended
    Download link is in first post.
    pseudo555's Avatar
    05.11.2004
    126
    3.3.29.0:
    I got redirect to "www.disk-tools.com/download/daemon+abpro+dtpro+sptd+hashcalc"
    Any idea ?
  8. #168
    10.08.2010
    1
    I have a problem with all this and nothing seems to work for me. I have the newest DTE which is compatible with win7 and I am using DT Pro Advanced 4.10.0218 . Now I wanna play Star Wars Force Unleashed Sith Edition and I installed it and everything. cloaking the vIDE is my problem, when i start DTE I can see the drive but I can't cloak it because the SecuROM is unable to be cloaked. No Emulation is ON or whatsoever. How do I make the SecuROM cloakable?
  9. #169
    Master
    Sway's Avatar
    09.07.2009
    1,966
    Try to use the latest DT Pro version.
  10. #170
    07.08.2005
    181
    I have Pro , IDE only, 4 36 03 09 , with SPTD 1.69 , windows7 x64
    DTE windows shows my only VIDE drive and nothing else which is correct since i dont have any optical drive connected.
    I only use AVIRA and Windows Firewall nothing else.
    The System is fresh installed with all updates and drivers.
    DTE shows for VIDE (DT vendor icon) drive that NO CLOAKING IS REQUIRED and the check boxes are GREEN.
    it will not stealth my drive from securom,
    conflict with emulation software deteced.
    doh!?!
