Page 18 of 19 FirstFirst ... 816171819 LastLast
Showing results 171 to 180 of 181
  1. #171
    That is normal. You have to use Load Driver feature.
    07.08.2005
    181
    I did that and it loaded the driver but after that accessing image on virtual drive slows down to a crawl !??!
    or to be more specific..severe lag in using DT features such as loading the GUI, mounting image, opening folders
    on the image etc.
    unloaded the driver and access is rocket fast again...Oo
    update: accessing files on SATA 2 drive on which the mounted image is located using explorer becomes all sluggish...
    file operations stall (copy file etc) ..WTF !!! currently copying a 23 mb file within same partition with a speed of 185 kb/s ...yes KB !!!
    This is SPOOKY !!!
  3. #173
    You also assigned vUSB to vDrive?
    Also which DTE version?
    07.08.2005
    181
    DTE Version from first post in the thread downloaded yesterday.
    No i ddint attach...didnt know how to ..but i found it now...
    (still its scary what happens to my IDE operations when using this and im talking about all operations on that SATA II drive while i have the image mounted and use DTE)
    I attached the virtual drive to a unused virtual USB port and got a new Drive now plus the DT drive. I mount the image in the DT Drive
    and can access it via the other drive (virtual usb) but its FREAKING SLOW . Takes about 2 minutes to load the folder structure of the image.
    going to reboot..scares the shit out of me ( i just have been thru a 600 GB data loss so im a bit nervous ^^^)
    ejected the virtual USB device using the windows USB safe remove Dialog, tried to unload the usb driver from insde DTE , unloading driver now
    STALLS and makes no progress. Closed DTE started it up again. Driver seems not to be present any longer. (Hopefully this stuff really leaves NO
    traces in my registry) I have a ASUS striker extreme, Nforce 680 I chipset (MS hotfix for nforce ehci usb 2.0 problems is present on this system)
    After all these operations shutdown of windows did stall ..had to switch pc off to restart.
  5. #175
    07.08.2005
    181
    scandisk on F; after reboot gladly no errors found. System is back to lightning speeds...will take step back from using this software. Too bad,
    but it makes me feel uncomfortable with all these weird side effects.
    i hate 20 minutes edit limits ...makes life complicated on a forum which may require to edit often such as in support questions.
    just in case it may be of interest:
    ASUS STRIKER EXTREME (uptodate bios)
    SSD OZC Revodrive PCI-E 120gb boot drive
    WD 1 TB EADS 00L5B1 Sata II HD
    4 GB Corsair Ram
    ATI 4870 1gb GPU
    Wolfdale 3.0 ghz core2duo
    Creative X-FI music PCI
    NOT OVERCLOCKED IN ANY WAY.
  6. #176
    4.40.0312.0214 is not working DAEMON Tools extensions v3.3.29.0
  7. #177
    Should be fixed in next DT Pro version. Currently DTE is not really needed due to attaching feature of DT Pro.
    when about to wait for new DT Pro version?
  9. #179
    There is no ETA yet, as usual.
    whre can I download the latest version? link seems dead
