Page 4 of 19 FirstFirst ... 2345614 ... LastLast
Showing results 31 to 40 of 181
  1. #31
    Please try attached DTE, it works with Comodo for me.
    Added command line interface, also some bugs fixed.
    Attached Files Attached Files
    24.09.2008
    14
    Yes, this version works fine, thanks.
  3. #33
    07.03.2008
    13
    Is DTE on Disk-Tools.com going to be updated?
  4. #34
    Will alert tech guy, so it will be updated.
    21.02.2009
    1
    Default Posts from DTE thread
    I use DT Pro 4.30.03, but DTE not work:
  6. #36
    You need Pro build 304.
    Also you have to copy DTE.exe to your installed activated DT Pro folder.
    You also have to activate at least one virtual drive.
    24.09.2008
    14
    I tried dte+dt.0304 (trial) with GTA4 v1.02 but no luck, it says that "emulation software detected", hmmm
  8. #38
    Do you see any SecuROM link? If yes, what does it say when you click on it?
    DTE says cloaked on vIDE?
    24.09.2008
    14
    I'm going to reinstall gta4 on fresh win xp3 today, will see if the problem persists...
  10. #40
    24.09.2008
    14
    Here the error message and link you asked for:
    The required security module not activated.
    This program can not be executed (5023).
    SecuROM
    p.s: yasu is not running at background, only dte. alcohol (with acid) is not installed at all...
