Page 5 of 19 FirstFirst ... 3456715 ... LastLast
Showing results 41 to 50 of 181
  1. #41
    24.09.2008
    14
    p.s: original gta4 image worked fine with dt pro.0303 + vIDE + latest yasu, but when I installed gta v1.02 patch, Securom started bothering me...
  2. #42
    Somehow ACID or YASU must run as DTE doesn't get detected by SecuROM yet.
    Also DTE doesn't have to be open.
    02.03.2009
    21
    Hello. I created crysis image (ISO file) with DT Pro Advanced 4.30.304 new securom profile.
    I used DTE latest version. I cloaked VIDE drive.
    But I could not play Crysis (v1.0) Securom is active.
    How can play without DVD ?
  4. #44
    You have to create mdf/mds image and not iso image.
    02.03.2009
    21
    it works. Thank you very much for your help.
  6. #46
    Default dte find no drives
    dte detects no drives
    http://i44.tinypic.com/53pd15.jpg
  7. #47
    25.03.2009
    3
    i have the newest one on the site, and my DTE crashes immediately after I run it.
    All I get is "Program has stopped Working" and then it closes
  8. #48
    Which OS (i guess Vista)?
    Which security software?
    Is UltraISO installed with a virtual drive (ISO)?
    And with latest version you meant 2.2.10.0?
    DAEMON TOOLS Extensions has stopped working :|
  10. #50
    Im having the same issue, it just closes on me, im using the newest DT evaluation software, and ive tried multiple DTE versions, all with the same issue
