Page 7 of 19 FirstFirst ... 5678917 ... LastLast
Showing results 61 to 70 of 181
  1. #61
    Thanks for the info - will take a look into PowerISO.
    EDIT: It seems PowerISO is using same/similar driver as UltraISO and therefore that bug. Will be fixed in next version.
    Ok, i tried to uninstall PowerIso, didnt work!
    Damn
  3. #63
    norsefire, have you other virtual drive software installed? Have you disabled virtual drive of PowerISO?
    Anyway next version will fix it.
    I finally got DTE working perfectly, although i still cannot get Wanted to work! I have a LEGAL Backup of the game since i dont want to bother with switching DVDs when i change games, i get securom error 7000 even when cloaked with IDE drive =(
  5. #65
    Have you tried the way from SecuROM website?
    Also please scan game exe with ProtectionID for exact SecuROM version.
    But since rafu997 get insert original message, it seems DTE is not blacklisted yet.
    Anyway i will check that game and SecuROM, just will take a while until the disc arrives.
    The game runs when i use the disc, but i hate using discs since i have a collection of approx 300 pc games, and maybe 30 games i play regularly.
    Update: Its SecuROM Detected - Version 07.39.0005
  7. #67
    @varxx
    which version of daemon tools pro is windows 7 compatible?
  8. #68
    None so far, you have to wait for SPTD update.
    25.03.2009
    2
    slowly getting there,
    DTE was not working due to the fact i had a MagicISO drive still active but now its saying "No cloaking required"
    anyideas?
  10. #70
    03.09.2005
    1
    Default DTE tool is useless
    It doesn't do anything.
    I double click the DTE.exe and all I get is this:
    It's a non interactive screen. There is no way to right or left click on it to select or set anything with this.
