Vista SP2 RC doesn't work with Deamon Tools
This topic is closed.
  • Vista SP2 RC doesn't work with Deamon Tools
    I just installed Vista x64 SP2 RC, and Daemon Tools Lite (latest version - 4.30.3) no longer works. I received an error stating "This program requires at least Windows 2000 with SPTD 1.56 or higher. Kernal debugger must be deactivated."
    I then tried to reinstall Daemon Tools and was informed that there was a problem with SPTD. I let the installer remove it and try to reinstall it, and received the same error message above.
    It seems Microsoft changed something (like in Windows 7) and SPTD doesn't load correctly anymore.
      sorry to bump this old issue, but I have the same problem
      vista 64 & the message [this program requires windows 2000]when trying to run Daemon.
      I was wondering if anyone can help me?
      Thx
        The8thDoctor, check Daemon Tools SUPPORT forum.
