Arma 2 Emulator detected+Yasu 1.6.9040+Deamon Tools Lite 4.30.4.0027
    There is a similar thread in the Customer section of the forum.
    It mainly depends on the chipset.
    Just wait for an updated YASU version.
    From what i've read those having issues mostly use XP.
    e.g. for me it also works with DT lite on both systems (AMD 780 & nforce 8300) in Vista x86 & Windows 7 x64.
      with patch 1.01 final is securom fixed from 7.40.0004 to 7.40.0005!
        Scanning -> C:\Program files\Bohemia Interactive\ArmA 2\arma2.exe
        File Type : Exe, Size : 16793600 (01004000h) Byte(s)
        [Heuristics] -> Flag : 00000000000000000000000000000001
        [!] SecuROM Detected - Version 07.40.0005
        - Scan Took : 0.656 Second(s)
          The Killing YASU method still works for me with 1.01 final too (Vista x64 on a P45 chipset).
          Upgrade your programs:
            me not work! chipsatz = p35 (asus p5kc)
              It was already 7.40.0005 with the Beta Patch
                betapatch in 7.40.0004!
                  I've just verified both 1.1.0.57631 (beta) and 1.1.0.57751 (final) have 7.40.0005.
                    I managed to get it working with DT Lite at last. I had the same problem as the others initially.
                    The problem for me was that I had PowerISO on my system as well, which created it's own Virtual drive. After I shut down powerISO and removed the drive, this time YASU was able to properly cloak the DT Virtual drive and the game ran smoothly. Oh, and I'm only using one Virtual Drive for DT Lite.
                    Btw , for those who can't get it to work using DT Lite, have you tried it with only a single Virtual drive? Maybe if you use several virtual drives, the game will detect them (as it happened in my case).
                      When release new version of YASU ??
                        I have the same PROBLEM here...
                        Hi Guys, still have the same problem here with the 1.0 vs of the game.
                        DT PRO 4.30.0305.0077 + YASU 1.6.9040
                        WINDOWS XP Sp3 + Atlhon 64 3800 + ATI Chipset in DFI LAN PARTY UT CFX3200
                        I Tried with SINGLE EMULATION and tried to DISABLE my PHYSCIAL OPTIC DISK too.
                        Anybody can HELP ?
                          When will there be a new version of YASU compatible with ArmA 2?
                          -[ Bzzt ]-
                            help? :x
                            Help please?
                            Windows 7 RC + DAEMON Tools Lite v4.30.4.27 + Y.A.S.U v1.6.9040 and not working!!! =(
                            I'm mounting the .ISO, oppening YASU/cloaking and finishing him. What am I doing wrong?
                              YASU gets detected by securom, thats why arma2 ain't working Hopefully there will be a new version released sooon!
                                @brfrodo
                                Also if SR wouldn't detect yasu, it wouldn't work for you. ISO doesn't contain copy protection related data, you need a MDS/MDF image with DPM info.
