have u got net framework 3.5 installed?
if not try this link.
Download details: Microsoft .NET Framework 3.5
if the link dont work google ' net framework 3.5 '
hope this helps
tony
hope this helps
tony
new version soon fix a few 64bit bugs
v3.4
requires .net framework 4.0 get from below link if you do not already have it.
http://www.microsoft.com/downloads/e...f-b21f31ab88b7
or google ".net framework 4.0" if the abave link does not work
ScripterNite v3.4 below link
2shared - download ScripterNite3.4.7z
remember the download link is at the bottom right ,where it says 'click here'
please let me know even if it is working ok , its been tested on xp32bit win764bit but should also work on xp 64bit, win7 32bit , and vista 32/64bit.
id like to know which version of windows it works or fails on
thanks
tony
if anyone has problems getting there scripts to work just post here.
new version soon v4.0
removed splashscreen its history
moved trayicon and balloontips from options to details tab, so now its per script basis
few other code changes
and yes it will open v3.4 scripts (you will have to open and resave them though)
added check for update
so im still waiting on people to let me know what versions of windows its working or failing on.
tony
ok its done
removed every bug i know about and hopefully didn't introduce any more
its a bit hard when i have to program and test cause no body gives any feed back (ive had one bug report to date)
so if anybody is interested ill upload it
thanks
tony
Hey toco1971. I'd like to work with you and test version 4.0. I'm running Windows XP Pro 32-bit on a Pentium D. I'm using Daemon Tools Lite. Post a link for 4.0 and I'd be happy to download and test it on Windows XP for you.
ok i can see the enthusiasm so im just gonna upload it
Download details: Microsoft .NET Framework 4 (Standalone Installer)
or google ".net framework 4.0" if the above link does not work
ScripterNite v4.0
2shared - download ScripterNitev4.0.7z
if you gonna download it at least send an email to let me know if its working or not
scripternite@live.com.au
thanks
tony
I just downloaded 4.0 Tony and it works great. Tested it in a non standard location to run it on Windows XP Pro SP 3 32-bit. I've used it a few times now to create a few scripts. I've also created shortcuts and they work great.
