Page 5 of 9 FirstFirst ... 34567 ... LastLast
Showing results 41 to 50 of 83
Thread: DaemonScript Clone Anyone Interested
  1. #41
    ok v4.0 had some new bugs so heres v4.1
    2shared - download ScripterNitev4.1.7z
  2. #42
    there is a small bug in the updater in v4.1
    just check back here for v4.2
    if u want to use the updater in v4.1 just place a file in the scripternite directory named dummy.txt before updating
    WHY:
    basically while updating scripternite.exe and interopshell.dll will get deleted and if the folder they are in is named scripternite and it is empty it will also get deleted, so when the updater goes to replace scripternite.exe it has no where to put it.
    But the new version will be sitting in the current users temp folder.
    this will be fixed in v4.2
  3. #43
    ok here it is
    2shared - download ScripterNitev4.2.7z
    ScripterNite v4.2 supports v3.1 scripts and on
    should autoupdate scripts as you open them, not as you run them. but they will run fine without being updated.
    thanks
    tony
    p.s make a backup of your scripts first just incase i stuffed something up.
    and leave some feedback you sad sad people
  4. #44
    20.11.2010
    19
    Just downloaded 4.2 and it works fine with my current scripts. Again on Windows XP Pro SP3 in a non standard location. Didn't try to do the internal update. I just downloaded your new one from 2shared.
  5. #45
    thanks for the feedback acid0057
    if u send me an email ill keep you up to date on scripternite,
    even tho the update should be working ok now.
    scripternite@live.com.au
    just so people know if you downloaded v4.1 i havent added the v4.2 to the update server because of the above problem i mentioned, so download v4.2
    thanks
    tony
  6. #46
    20.11.2010
    19
    Thanks Tony. I just sent you an email. Still haven't encountered any problems with 4.2 on my machine.
  7. #47
    thats good cause if you hit update you can tell me if v4.3 via update works
    so everybody out there if u want v4.3, download v4.2 and hit update.
    added instance by filename to waitforapp and terminateapp, so now you can type for example. calc, calc.exe or c:\windows\system32\calc.exe. all will work for instance by filename.
    couple of other code improvements, cant remember them all
    let me know how it goes.
    thanks
    tony
  8. #48
    1 forgot to mention, v4.3 only opens v4.0 and on scripts
  9. #49
    v4.4 is uploaded to server so click update and let me know how it goes.
  10. #50
    20.11.2010
    19
    Updated through the internal updater to 4.4. Worked great. Opened my saved 4.2 script and saved it again in 4.4. Tested the shortcut created and works great. No issues here Tony.
