Page 6 of 9 FirstFirst ... 45678 ... LastLast
Showing results 51 to 60 of 83
Thread: DaemonScript Clone Anyone Interested
  1. #51
    just for the info. once you open an old script it will auto save to the new version, so no need to save manually.
    note an old script will run fine without being updated, so you dont really need to update your scripts they will be the same just with a older version number. i think v4.2 removed the waitforapp timeout that should never be needed any way.
    if you want to update all your scripts at once just select 5 - 10 at a time and right click and say edit script. 5 - 10 should be safe, depends how much memory you got available, just allow about 20MB per script 10 x 20MB = 200MB free memory.
    once their all open just close them all and there updated
    make a backup of your scripts first
    v4.3 and on, only support v4.x scripts
    by request i may make 'a version' that will open v2.4 scripts and on just so people can move to the newer versions more easily. not that i want to.
  2. #52
    im fixing a bug I found (like usual) in mount/unmount when using dtpro.
    why know body can email me and tell me theres a problem , i just dont know.
    im just waiting on a reponse from the below thread
    http://forum.daemon-tools.cc/f14/dta...40/#post129509
    then ill release v4.5. feel free to try the test i mentioned in the above thread, and let me know if u can reproduce my problem or not. requires DTProAdvanced v4.40.0311.0197
    tony
    p.s my dtpro trial will run out soon then the testing will be left up to yourselves.
  3. #53
    20.11.2010
    19
    I'm using DTlite here Tony sorry I can't repro that bug for you. 4.4 works fine with the Lite version though.
  4. #54
    i have uploaded v4.5 to server
    should have fix for dtpro mount\unmount
    and several other code improvements.
    also auto updates scripts as you run them or open them
    and yes im still waiting on response from the thread in the above post #52
    thanks
  5. #55
    20.11.2010
    19
    Updated to 4.5 thanks for that Tony. I wish I could test the DTPro but I don't have a copy. I just use DTLite.
  6. #56
    v4.6 is uploaded to server
  7. #57
    v4.7 is uploaded to server\
    fixed a newly introduced bug when creating embedded file 'interop.shell32.dll' on first run
  8. #58
    20.11.2010
    19
    Updated to 4.7. Working fine here. No problems to report.
  9. #59
    "v4.7 is uploaded to server"
    I can only find up to V 4.5 on 2shared - file upload.
    Different server?
    Maybe good to make a real - clickable - link in your messages...
    Love to go test/use your program.
    I used another "DaemonScript" on old machine. Can't find any reference to that anymore.
    Greetz, Casey
  10. #60
    20.11.2010
    19
    @Casey: He only put up to 4.5 on 2shared. What you need to do is download 4.5 run it and click on the update in the program. It will download 4.7 and update to it for you.
