Showing results 1 to 5 of 5
Thread: Shortcut problems
    17.12.2002
    2
    Default Shortcut problems
    Hi,
    I have the following problem with the shortcut that i make:
    It loads the image but it doesn't start the command to execute the program.
    At the bottom you will find the code that i use.
    I think that it's a time problem, the execution of the program starts before the image is coupled.
    Is there a timepause command or something to wait for the image to be coupled, or am i doing something wrong?
    My code:
    K:\NIJNTJE\NIJNTJE6\NIJNTJE6.EXE "c:\Program Files\D-Tools\daemon.exe" -mount 0,"M:\Spelen\nijntje en haar fiets\NIJNTJEENHAARFIETS.CUE"
    Thanks for the help
    Doowie
    I will send you my delay program.
    17.12.2002
    2
    Default Problem solved
    Thanks David Andareed for the help, it is a nice tool and works fine.
    The delay thing is actually included in the DaemonScript Editor, if I am not wrong
    Cordially,
    Abel K.
    http://www.ngnicafe.com
  5. #5
    It is. But I use delay.exe so i can read the results of some long batch file without needing to press a key...
