Showing results 1 to 3 of 3
Thread: need some help
    Default need some help
    after installing deamon tools trial version on my vista systhem all my exe file open now with deamon tool WTF i never have experianced this with xp
    how can i fix this
    i tried systhem repair but i cant acces it becoz its a exe file and it will open deamon tools instead of systhem repair nothing works anymore
    any ideas how i can repair my exe files ?
    thanks pieter
    Master
    Sway's Avatar
    09.07.2009
    1,966
    Create .reg file with the following content:
    Windows Registry Editor Version 5.00
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\FileExts\.exe]
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\FileExts\.exe\OpenWithList]
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\FileExts\.exe\OpenWithProgids]
    "exefile"=hex(0):
    Execute created file via double click. Then restart your PC.
    thx
    i tried that but it did not work
    so after some googling i did found this :
    [HKEY_CLASSES_ROOT\.EXE]
    @="exefile"
    "Content Type"="application/x-msdownload"
    [HKEY_CLASSES_ROOT\.EXE\PersistentHandler]
    @="{098f2470-bae0-11cd-b579-08002b30bfeb}"
    [HKEY_CLASSES_ROOT\exefile]
    @="Application"
    "EditFlags"=hex:38,07,00,00
    "FriendlyTypeName"=hex(2):40,00,25,00,53,00,79,00, 73,00,74,00,65,00,6d,00,52,\
    00,6f,00,6f,00,74,00,25,00,5c,00,53,00,79,00,73,00 ,74,00,65,00,6d,00,33,00,\
    32,00,5c,00,73,00,68,00,65,00,6c,00,6c,00,33,00,32 ,00,2e,00,64,00,6c,00,6c,\
    00,2c,00,2d,00,31,00,30,00,31,00,35,00,36,00,00,00
    [HKEY_CLASSES_ROOT\exefile\DefaultIcon]
    @="%1"
    [HKEY_CLASSES_ROOT\exefile\shell]
    [HKEY_CLASSES_ROOT\exefile\shell\open]
    "EditFlags"=hex:00,00,00,00
    [HKEY_CLASSES_ROOT\exefile\shell\open\command]
    @="\"%1\" %*"
    "IsolatedCommand"="\"%1\" %*"
    [HKEY_CLASSES_ROOT\exefile\shell\runas]
    [HKEY_CLASSES_ROOT\exefile\shell\runas\command]
    @="\"%1\" %*"
    [HKEY_CLASSES_ROOT\exefile\shellex]
    [HKEY_CLASSES_ROOT\exefile\shellex\DropHandler]
    @="{86C86720-42A0-1069-A2E8-08002B30309D}"
    [-HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\FileExts\.exe\UserChoice]
    that one did work with vista all exe where working aggain only some service stuff was dissabled and shit so to save time i did a frormat a put xp back on problem solved
    vista sucks bigg time
    anyway thx for the reply
