Showing results 1 to 6 of 6
Thread: Internal Setup Error. Error Code:14. Contact Support
    28.10.2009
    3
    Default Internal Setup Error. Error Code:14. Contact Support
    hi guys, im currenlty using windows vista x64, and have downloaded:
    -daemon410-x86
    -daemon4304-lite
    -daemonToolsPro4350306
    -daemonTools Lite 4.12.1
    none of them has worked and im fustrated! I'm not sure what's wrongs, but mostly the "Internal Setup Error. Error Code:14. Contact Support" comes up.
    can any1 please kindly help me?? thanx a lot in advance!! =D
    Master
    Sway's Avatar
    09.07.2009
    1,966
    Disable ALL security software.
    28.10.2009
    3
    thanx so much for the fast reply..but im a newbie with all this, what do you mean by security software? as in like the antivirus and stuff?
    Master
    Sway's Avatar
    09.07.2009
    1,966
    Antiviruses, firewalls, etc.
  5. #5
    28.10.2009
    3
    thanx SWAY for all the help!! i've actually just burned my program to CD, and it worked perfectly fine without daemon! though i did try turning off all the antivirus and firewall, it still didn't work! >.<" but thanx so much for your help and time anyway! =)
  6. #6
    GEORGIAN TRANSLATOR OFFICIAL TRANSLATOR
    sikvdila's Avatar
    05.07.2008
    138
    also disable UAC (USer Account Control) in control panel, and run installer as adminsitrator
    Georgian Translator
