Showing results 21 to 30 of 40
Thread: Asking for SPTD 1.60???? Help please.
  1. #21
    11.01.2010
    13
    Okay... Thing is I'm able to run these programs together on another computer. All same version and settings. Why am I running into problems on this one?
  2. #22
    Quote Originally Posted by Copytrooper View Post
    OS upgrade screws SPTD configuration.
    Delete Daemon Tools installation folder, disable SPTD in registry, i.e. open regedit, go to
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\sptd
    and change Start to 4, then reboot.
    After reboot enable all permissions of sptd/cfg key, then delete entire sptd key, and reboot again.
    Now re-install.
    can someone give a more understandable explanation for people who haven't used regedit before? cheers.
  3. #23
    I have been jumping through these hoops all afternoon to get DT installed with no luck. Yes I was able to delete the SPTD keys etc.
    but It wasn't until I deleted ZONEALARM 9.1 that I was able to install DT.
    This admins tip about forcefield getting in the way was correct.
    DL Lite successfully installed on Win 7 x86. by removing Zonealarm.
    Problem Solved.
  5. #25
    Managed to run Daemon tools by following the instructions on Blaskowicz' link but now everytime I mount an image or play a game using the disc it run's for about 30-60mins and then without warning suddenly shuts down. Any ideas?
  6. #26
  7. #27
    Running Windows 7 Home Premium - Upgraded from Vista Home Premium
    No virus software
    I followed the instructions to fully delete the sptd key, then rebooted, checked, and the sptd key was completely gone under HKEY_LOCAL_MACHINE.
    I rebooted again, and then reinstalled DT Pro, and still got the same exact message.
    any other thoughts?
    thanks in advance.
    -e
  8. #28
    Im new to all of this. I received the same message. Im running XP. Please help!
  9. #29
    Master
    Sway's Avatar
    09.07.2009
    1,966
    Follow this guide to reinstall DT/SPTD - DAEMON Tools Professional Help: Registry and SPTD problems
  10. #30
    WinXP Pro SP3
    ZoneAlarm Extreme Security 9.1.008
    NOD32 Antivirus 4.2.35
    Daemon Tools Lite 4.35.5.68
    SPTD 1.62
    FROM THE BEGINNING
    Normal Mode:
    "Internal setup error. Error code: 14. Contact support."
    Safe Mode:
    Successfully installed DT
    Normal Mode:
    "This program requires at least Windows 2000 with SPTD 1.60 or higher. Kernel debugged must be deactivated"
    Uninstalled antivirus:
    DT worked without any problems.
    Antivirus installed again:
    Uninstalling, reinstalling DT, separate installation of SPTD, registry modifications, disabling security software etc.:
    Useless stuff!
    Any Ideas?...
