Updated DT Lite 4.35.5 gadget
    That feature is loaded as a service and requires a reboot. Even when Comodo is disabled, that service is still running.
    I'm not aware of any issues with Avast.
      Well, the service is permanently disabled, I rebooted, but still no gadget love. Any suggestions?
      Thanks again for your quick responses, deeply appreciated!
        Do you see any errors in Event Viewer?
        EDIT: Other gadgets are working?
        Also try the following:
        Start -> regedit -> HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Sidebar\Settings -> AllowElevatedProcess
        Value: 1
        AllowElevatedProcess is a DWORD which you probably have to create.
        Then restart Sidebar or pc.
        Another try would be:
        Delete C:\Users\USERNAME\AppData\Local\Microsoft\Windows Sidebar\Settings.ini
          Good grief! What did they do to the event viewer?? Anyway, no, nothing related to DT Lite. The 4 issues I see re-occuring are:
          Apparently there is some HP log file missing.
          Wininit is concerned about custom dll files loading, wants me to check them.
          WLAN is shutting itself off.
          User Profile Service is getting stuck on boot and reloading itself, successfully.
          One scary error about Hard Drive 2, but that's it.
          Next?
            Did you try the things I edited in my last posting?
              Nope, just saw that now, I will look at it and report back.
              The warning about the disk error MAY be related to DT Lite, but according to Microsoft it's basically a useless Warning it throws up when it's buffering multiple devices.
                Yes, other gadgets are working just fine. There WERE a handful of gadgets in the online repository that didn't work for me, but I assume they were made for Vista or x86 or something. I have 5 gadgets up and running, none of them stock.
                I don't have a Settings key (folder) there. I did find one listed under: HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Sidebar\Settings
                Should I put it there or..?
                Also, no Settings.ini file there, I found one under: C:\Users\Michelle\AppData\Local\Microsoft\Windows Sidebar
                ..either way, what did you want me to do with it?
                  First question is yes.
                  2nd backup settings.ini and delete -> reboot.
                    Still doing the same thing. Oddly, every time I open the Gadget manager thing, it adds the GCPU gadget. Anyway, here is a copy of the newly created Settings.ini:
                    Code:
                    [Root]
                    SettingsVersion="00.00.00.02"
                    SidebarDockedPartsOrder=
                    ShowGalleryPrivacyStatementOnceComplete="true"
                    [Hashes]
                    C:\Users\Michelle\AppData\Local\Microsoft\Windows Sidebar\Gadgets\DT.gadget="%7BA11A7A40-22F8-3B9D-9499-5FC7A3811914%7D"
                    C:\Users\Michelle\AppData\Local\Microsoft\Windows Sidebar\Gadgets\GCPU.Gadget="%7B03954A9A-6F70-2F8E-96A0-76C77FFE24BC%7D"
                      Did you actually try to reinstall DT with the Gadget?
