Showing results 21 to 30 of 38
Thread: DT 4.3.55 & Windows 7 - Can't Add Virtual Drive
  1. #21
    Customer Terramex's Avatar
    06.09.2004
    2,566
    Quote Originally Posted by nickoz5 View Post
    Firstly, I have a completely clean install of Windows 7 on my machine. No drivers/tools were installed from the HP support site at all.
    As the only non-HP specific tool: what about Intel Matrix Storage Driver/Manager ?
  2. #22
    Nope, didnt install that either since I'm not running a RAID configuration at the moment (just using two 136GB SAS 15K HDDs separately).
  3. #23
    08.02.2010
    1
    Default same issue
    I have a brand new HP 600, with no HP utilities or managers installed, and getting the same message above. I've been using daemon tools for years on many different machines. I can't figure this one out. I've tried uninstalling, etc.
    i see you are all having problems. I hope this is being looking into.
  4. #24
    12.02.2010
    2
    I am having the same problem with my Lenovo Thinkpad, running windows 7 64 bit.
  5. #25
    Reply from support;
    Now, we have several reports from our users who uses HP Z-series about the same problem, so this problem became known issue.
    We forwarded all information to our devs. They are investigating the problem.
    We will contact you as soon as we find the solution.
    Sorry for any inconveniences.
  6. #26
    Darth Vader
    SUPPORT2's Avatar
    21.05.2007
    205
    Hi
    please, look here
    http://forum.daemon-tools.cc/f26/hew...problem-26228/
    So, we just need to wait for the new SPTD version.
  7. #27
    02.03.2010
    5
    Quote Originally Posted by tsaber View Post
    same here on my T410 64 bit and I can't seem to figure it out. I installed alcohol 120% and see if I can create a virtual drive, it also run into the same problem: unable to add adapter, ACPI function must not be disabled. This SUCK!
  8. #28
  9. #29
    02.03.2010
    5
    already went through that and nothing work.
  10. #30
    Master
    Sway's Avatar
    09.07.2009
    1,966
    Did you try to disable/uninstall your security software? What exactly do you use?
