DT 4.3.55 & Windows 7 - Can't Add Virtual Drive
  • #31
    Originally Posted by Sway View Post
    Did you try to disable/uninstall your security software? What exactly do you use?
    I didn't install any software when I installed DT Lite (I installed it right after I did a clean install of windows 7). Between I use NOD32 antivirus and Outpost firewall.
    A few months ago when I had a T400 running windows 7 32 bit I was able to install DT Lite with both NOD32 antivirus and Outpost firewall running at the time. I just have a feeling it has to do with windows 7 64 bit and acpi function being disable.
    • #32
      Originally Posted by tsaber View Post
      I am having the same problem with my Lenovo Thinkpad, running windows 7 64 bit.
      Same here! My thinkpad is T410 with 32-bits winxp, and DT or Alcohol 120% returns 'ACPI must not be turned off in the BIOS', but there is no such option in the BIOS.
      • #33
        I think I'm having the same issues as everyone else though in device manager i also get a "not enough resources" error when the device is trying to be added, does it say that for you guys too?
        i have a thinkpad t510, i updated the bios to the most recent version available by Lenovo but that didnt help.
        • #34
          I have the EXACT same problem also with a Lenovo Thinkpad!
          32 bit Windows 7.
          • #35
            I have the EXACT same problem also!
            Is anyone adressing this issue at all??
            Lenovo Thinkpad W510, 64 bit Windows 7.
            All brand spanking new!
            • #36
              I just sorted it on my Thinkpad Lenovo W510 (W7 64 bit), by installing (updating) the SPTD from 1.62 to the new one 1.72!
              There is an 32 bit version and a 64 bit version.
              rebooted and volá! Finally!
              • #37
                update the SPTD to the newest:
                DuplexSecure - Downloads
                • #38
                  Hi all
                  Seems the problem is very similar to the problem which was reproduced on HP Z-series systems
                  You need to use latest SPTD driver v.1.72 from DuplexSecure
