Error in command line? HELP QUICK
  • Error in command line? HELP QUICK
    Okay, I was trying to install something with Daemon Tools Lite when everything suddenly has a little Daemon Tools icon. Instead of an icon, the programs has a small DT icon instead, and when I try to start them, it says: "Error in command line". How can I solve this? PLEASE HELP! :'( My mom is gonna kill me if she finds out!
    PS: I deleted the Daemon Tools programme, and tried to reinstall it, but I can't install stuff!! :'(
    When you try to start what?
      Programs :S F. ex when I press Internet Explorer, it just says: "Error in command line", the only reason I managed to start it was because of a online readme.
        HKEY_CLASSES_ROOT\exefile\shell\open\command
        Ensure "Default" is:
        Code:
        "%1" %*
          Well, um, where do I find that?
            Regedit of course.
              I open "Drive", but it can't find REGEDIT!
                What about typing it into Start -> Run?
                  I meant "Run" :P
                    If it can't even find the simple program regedit, windows is screwed up.
                    You may check c:\windows\ for regedit.exe and run it from there.
                    You may check regedit.exe to start through cmd.exe
                    • #11
                      I found it, but what program should I use to open it?
                      • #12
                        What program should I open regedit in?
                        AND, I found out that all the .exe files is the ones that aren't working.
                        • #13
                          None, exe starts itself.
                          OK, start creating a reg file and import it (double click on this reg file) with contents:
                          Code:
                          REGEDIT
                          [HKEY_CLASSES_ROOT\exefile\shell\open\command]
                          @="\"%1\" %*"
                          • #14
                            Well, I can't start it. It asks me what program I wanna open it in :S
                            • #15
                              Reg file doesn't care about exe.
