Page 1 of 3 123 LastLast
Showing results 1 to 10 of 25
Thread: Daemon Tools Not Mounting ISO Files
    Default Daemon Tools Not Mounting ISO Files
    Title basically says it all. Once I try to mount a file, in this case I've been trying to mount an ISO file, it attempts to mount it.... but nothing happens. In other words it doesn't open the file I want to mount. I've beem looking around the forums and saw that it could have something to do with a couple Microsoft updates I could've installed. If this is a repeated thread I do apologize and thank you in advance.
    Master
    Sway's Avatar
    09.07.2009
    1,966
    What is your DT version?
    Is a drive letter assigned to the virtual device?
    Unglücklich same problem
    i have the same problem and i just downloaded the DT lite 4356.
    this isn't the first time i mounted this ISO image to a computer so i don't understand why it's not working
    i would click to mount the image and the "mounting" thing pops up in the middle of the screen for a few second and nothing happens after...
  5. #5
    Master
    Sway's Avatar
    09.07.2009
    1,966
    Can you browse your virtual drive via My Computer or any other file manager?
  6. #6
    Having the same problems with it...
  7. #7
    same problem with iso files and the new version DT 4356. These iso files mounted with the older version of DT. Only started problem with new upgrade to DT 4356
  8. #8
    Master
    Sway's Avatar
    09.07.2009
    1,966
    What is the "same problem"?
    Which way did you mount an image?
    What is the result of mounting?
  9. #9
    12.01.2011
    1
    Hello may I ask how to mount image. I'm using DTlite 4.40.1.127 (winXP sp3) and when i try to add an image DTlite just broke. i was using Dtlite before and i had never had any problems about mounting
  10. #10
    Master
    Sway's Avatar
    09.07.2009
    1,966
    Quote Originally Posted by klica View Post
    Describe the problem more detailed. What do you mean DTLite just broke?
