DAEMON Tools Pro Driver Error: 3
  • DAEMON Tools Pro Driver Error: 3
    When I want to add a virtual SCSI device I get the following error: DAEMON Tools Pro Driver Error: 3.
    I have looked on the web but I couldn't find any solutions to this problem. Please tell me what to do.
    Thank you.
    Is there an exclamation mark in device manager?
    Any error in event viewer?
    EDIT: You also can try to uninstall DT and then after a reboot to reinstall it.
      If by device manager you mean the mount n drive manager then there is no exclamation mark there.
      I don't know what you mean with event viewer? How do I open that one?
      I'll now try to uninstall and the reinstall. Thx
        Both are parts of Windows.
        Also ensure you are using latest Windows updates and latest DT.
          I may know what the problem is. Daemon tools says the 'device' it created is E:\. While actually, it created the F:\; the e:\ is my real cd/dvd-station.
          How can I change that?
            DAEMON Tools Lite Help: Virtual Devices' Configuration
              That won't work because I have no virtual devices yet. I still have to 'make' one. It could be that I still have the F:/ because I have uninstalled Daemon tools earlier.
              But is there another way to make Daemon Tools select the F:/ and not the E:/?
              Thx a lot
                Windows is doing drive letter assignment.
                You may use Disk Management (Control Panel -> Administrative Tools -> Computer Management) to change drive letter of your physical one (E.
                If you haven't created one yet, you should first find out what F: really is (e. g. from another virtual drive software).
                And if it is a left over, you may delete it in Device Manager.
                  Did all of that and all of the things you suggested. However, it still doesn't work and still says: "DAEMON Tools Pro Driver Error: 3".
                  Still thanks for your help. I know this is a bit unthoughtful to ask, but are there any programs on the web similar to DAEMON Tools, so I can try that?
                  Thx 4 all the help.
                    You haven't answered the questions regarding Event viewer and Device Manager yet.
                    Take also a look at http://forum.daemon-tools.cc/f19/dae...ror-1-a-22852/
                    • #11
                      Have already looked on that post, but also didn't work. By the way, sorry I forgot to answer those questions. No exclamation mark in Device Manager and no errors in Event Viewer...
                      I'm now downloading virtual cd (program like DAEMON Tools). Sorry for that, I like Daemon Tools a lot, but it just doesn't work on my laptop.
                      Thx for all the effort.
                      • #12
                        answer
                        Hey there, I had the same problem like you and I fixed it very easily...right click on the daemon tools icon in the taskbar (next ti the clock) and go to preferences-> advanced-> and disable Advanced Simulation. That's it, well for me it was, after this worked perfectly and the error message disappeared
                        • #13
                          saemon tools pro driver error 3
                          i hve the same problem but i cannot find the advanced preferences on daemon tools...
