Showing results 1 to 6 of 6
Thread: Daemon Tools Lite BD-ROM Problems
    14.04.2010
    4
    Ausrufezeichen Daemon Tools Lite BD-ROM Problems
    Sorry if I should not have started a new thread.
    I am having problems with daemon tools lite on windows 7 64-bit. I installed a few games and programs using daemon tools and now my BD-Rom doesn’t pick up Dual layer discs. Before I installed daemon tool I could burn Dual layer discs. I had a look in device manager and now the BD-Rom drive thinks it’s a CD-ROM drive See image (http://img405.imageshack.us/img405/4229/bdrom.jpg). I tried updating BD-Rom drive firmware updating daemon tools uninstalling/reinstalling BD-ROM drivers and uninstalling daemon tools + deleting reg keys but it still doesn’t pick up Dual layer discs. This is not a problem with the drive as I have tested it in a different PC and it works fine.
    Any Ideas??
    Again sorry if I should not have started a new thread.
    Mark
    You do tried to deactivate every emulation option?
    14.04.2010
    4
    Well I uninstalled daemon tools and daemon tools is the only disk image emulator software I have on my PC would that not deactivate emulation option??
    Sorry I am a n00b!
    I was talking about in DT, try to reinstall it and check it.
    Also ensure you don't have Alcohol installed (this program has also such emulation option).
    14.04.2010
    4
    Reinstalled and removed the drive emulation and I don’t have Alcohol installed but it still isnt working. The last time this happened I had to rebuild my PC
  6. #6
    14.04.2010
    4
    So is there no fix for this then??
