Showing results 11 to 20 of 29
Thread: Error: Core library wasn't found
    +1 for this error.. could someone point us in the right direction to fix? we can't uninstall or reinstall..
    same problem here since I´ve updated to version 4.35.6.91..
    Befor the update, the program ran without any problems..
    But now I can´t even uninstall it...
    Moderator
    Sway's Avatar
    09.07.2009
    1,966
    Try to delete DT files/folders manually and then reinstall the program.
    P.S. What is your security software?
    kaspersky.....
    Default Missing Core Library
    Manually deleting the files/folders did not allow me to reinstall successfully (still got an error about software not being properly registered (and I think it means registered within windows, not registered purchase/license/etc)
    I finally gave up and brute forced it by backing up my registry, searched on daemon and removed almost every instance/key pertaining to daemon tools (I left things that were items like IE last browsed page that were references to daemon). Rebooted, and the DTLite4356-0091.exe version installed fine that time around.
    Moderator
    Sway's Avatar
    09.07.2009
    1,966
    Great!
    Default Some noob question
    I have the same problem, but sorry for asking, how can i delete all registry that u mention before. Anyone can help me with this please?
    I really appreciate your help.
  8. #18
    15.08.2010
    3
    The same problem, vista64, avast. The new version is not working, it cannot be even reinstalled, I accept that. But why the f*k cannot I go back and install the old version???
  9. #19
    open DaemonToolsLite4356-0091.exe(installation file) with 7zip and copy Engine.dll, imgengine.dll to folder with daemon(C:\Program Files\DAEMON Tools Lite)
  10. #20
    15.08.2010
    3
    When I 7zipped the installation file, i got these files
    01.04.2010 11:18 512 .data
    01.04.2010 11:18 0 .ndata
    01.04.2010 11:18 6˙656 .rdata
    01.04.2010 11:18 9˙551˙872 .rsrc
    01.04.2010 11:18 25˙600 .text
    01.04.2010 11:18 5˙440 CERTIFICATE
    no dll file...
