Page 3 of 3 FirstFirst 123
Showing results 21 to 29 of 29
Thread: Error: Core library wasn't found
  1. #21
    Customer Terramex's Avatar
    06.09.2004
    2,566
    Quote Originally Posted by T_xy View Post
    When I 7zipped the installation file, i got these files
    Are you using a up-to-date version of 7Zip ?
    Have you downloaded the DT Installer from official sources (disc-tools.com or disc-soft.com) ?
  2. #22
    Terramex, I did check it 2 month ago with latest 7Zip, same as T_xy reported.
    06.09.2004
    2,566
    Strange, i've checked it 2 minutes before my post - no problem with v4.65
    Also no problem with Uniextract (which uses the 7Zip beta dll).
  4. #24
    15.08.2010
    3
    It finally works. My problem was in suffix, with .7z it extracts the weird way, with .7zip it works correctly. I had to copy CSY.dll and ENU.dll in Lang subdirectory too, otherwise there was no text. Thank DDrVostep for solution and the others for patience.
  5. #25
    06.09.2004
    2,566
    If it's ever needed again (hopefully not ), just let the extension well enough alone - it's working fine with .exe
  6. #26
    03.01.2011
    1
    Hi all
    Actually I have the same problem + another problem which is the 7zip is not working correctly, It just gives me a report with an error while extracting the missing files from the .exe into the dt lite directory. Any help?
    I thought maybe someone can do me a favor and upload the missing files on mediafire or such file hosting webs or something. Thanks
    Yeah and the version I'm using is DTLite4356-0091
    And as you already know I can't uninstall or reinstall it, so I'm stuck
  7. #27
    Add another to the list, I got the same error, and will try the recomended fix, but I have to say, if the only problem is that the files are missing then the installer is clearly flawed, and should be replaced with one that works. IMMEDIATLY!
  8. #28
    Thank you Terramex, your fix has restored my abillity to use Mechwarrior 2! yay
  9. #29
    06.09.2004
    2,566
