Page 3 of 3 FirstFirst 123
Showing results 21 to 26 of 26
Thread: Option to disable automatic emulation.
  1. #21
    Customer Terramex's Avatar
    06.09.2004
    2,566
    @moonie
    - he's using an image without bad sectors in Alcohol's virtual drive -> doesn't work (showing a typical error message)
    - then he's turning on BAD Sectors Emulation in Alcohol -> working
    Hence it's no blacklist problem.
  2. #22
    Would you please define where you're running into trouble ?
    In which practical situations do you face disadvantages with this SD auto emulation ?
    Trouble is - I want to be sure that my sd protected backups are 100% legit. Currently I MUST use alcohol52% for testing this. Because even if protection not cloned fully - DT still run this backup from virtual drive w/o warnings. And "burn cd-r - test" method is wrong way.
    This is the only cause for my suggestion.
    Quote Originally Posted by Development View Post
    If you enabled SD emulation in Alcohol then setting in DT does not matter then - SD emulation is enabled globally for all CDROMs in system if at least one program enables it. Behavior of Alcohol and DT is same.
    Sorry, but no - I know what I doing. I disable sd emulation in A52 before testiong. I even uninstall A52.
  3. #23
    Sorry, but I'm not so unskilled.
    Safedisk emulation in A52% was disabled.
    Plus to be completely sure I even uninstall A52%.
    Still the same results.
    I buy the old boxed pc games for my collection sometimes. Then I make hdd backups and use backups only - no cd scars, faster install/running etc.
    With this "auto safedisk emulation for virtual drives" all my sd 1x-2x backups can be inaccurate.
    Currently I forced to use A52% for check. Or cd-rw burn/test routine.
  4. #24
    06.09.2004
    2,566
    Quote Originally Posted by Gamecollector View Post
    Safedisc emulation in fact emulates bad sectors only .
    No drive has problems reading/storing the bad sectors (besides speed of course), only the weak ones can be problematic for few drives - but they aren't affected by the emulation.
    So your images (with bad sectors) are 100% legit - at least that emulation doesn't adulterate your tests.
    But maybe Development still drops it - we will see
  5. #25
    Default Disable Emulation
    I am trying to use my Need For Speed Pro Street disc in the disc drive but it keeps telling me there is an error with emulation. This is NOT an iso. I was uable to create an iso for this game. Is there any way to disable the emulator without having to uninstall it completely?
  6. #26
    Master
    Sway's Avatar
    09.07.2009
    1,966
    How did you get this image file?
