Page 1 of 2 12 LastLast
Showing results 1 to 10 of 15
Thread: USB hard drive stopped working after DTL installation
    08.06.2010
    9
    Unglücklich USB hard drive stopped working after DTL installation
    Hi,
    my 500GB USB hard disk worked well all the time, until I installed the latest version of Deamon Tools Lite on my Windows 2003 x86 server.
    Please help me and tell me what I should try to get it back like it was before (I don't need a virtual CD drive).
    I try to give as much info as possible, please ask for more:
    The automatically created new virtual CD drive got its drive letter E:, and showed instead of the USB disk. So I changed the drive letter for the virtual CD drive to V:, but it didn't help: my drive E: didn't reappear, even not after a second reboot (first was for SPTD installation).
    So I tried to unplug/plug the USB disk in combination with reboots and many tries to assign a drive letter in windows disk management. There I always got an internal error and the hint to look into the system log, but there was nothing interesting.
    So I uninstalled DTL including reboot, no change.
    So I uninstalled SPTD including reboot and check that all files are really gone, no change.
    I also installed the latest version of SPTD manually and uninstalled it again, no change.
    I tried the USB disk in a different computer, there it worked like always.
    I tried a different USB stick in this computer, and it worked. So it's not a general failure of USB disks - just for this drive.
    I got access to the disk by mounting it with Paragon Partition manger. Interestingly, there the mounting worked and the drive showed as E: in the file explorer. File operations of any type work, but windows partition manager doesn't show the driver letter assignment and still shows internal errors on any operation including viewing the properties. It even assigns this same drive letter E: to my other USB drive when I plug it in.
    The drive letter E:, mounted by Paragon, stays when I unplug the USB disk (unlike how it was before).
    After a reboot the disk is gone again, windows can't mount it, and I can use Paragon again if I need access.
    The windows partition manager (gui and diskpart tool, too) don't show the volume in the volume list. So, in diskpart I cannot select it, and therefore not try to mount it.
    In the GUI tool, it is also not shown in the (normally hidden) volume list, but it is shown in the graphical display, without a drive letter. But I cannot use any options there, I always get "the operation didn't complete" or "internal error" (translated from german!).
    After lots of tries and lot of reboots, I have no idea.
    Any hints?
    Master
    Sway's Avatar
    09.07.2009
    1,966
    Do you have drivers for your USB hard disk? Try to reinstall them.
    08.06.2010
    9
    I don't have specific drivers for it, but I already uninstalled the driver from the device manager, then plugged the device out and in and windows reinstalled them -> no change.
    Administrator
    06.11.2002
    2,044
    You can try to clear HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
    and reboot.
    This will clear all current letter assignments.
    Then you can try reassign letters for all drives.
  5. #5
    08.06.2010
    9
    Quote Originally Posted by Development View Post
    and reboot.
    It looks like this:
    [HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices]
    "\\??\\Volume{532f9ec0-5432-11dc-8dd4-806e6f6e6963}"=hex:...
    "\\??\\Volume{532f9ec3-5432-11dc-8dd4-806e6f6e6963}"=hex:...
    "\\DosDevices\\C:"=hex:...
    "\\DosDevices\\D:"=hex:...
    "\\??\\Volume{ebd33f88-a10f-11dc-b64a-806e6f6e6963}"=hex:...
    "\\DosDevices\\W:"=hex:...
    "\\??\\Volume{f153dc01-72d3-11df-bc16-001921211740}"=hex:...
    "\\DosDevices\\E:"=hex:...
    fyi: E: is not shown in the Explorer, it used to be that USB drive.
    I wonder what all those ?? devices are. I just have C: (2 raid harddisks), D: (harddisk), and W: (dvd)
    Maybe it's a good idea, just to delete that E: key?
    Or is it 100% secure and can not do any harm to delete all of them?
  6. #6
    08.06.2010
    9
    I found that the 4 "DosDevice" entries had the same binary values than the 4 "??" entries and deleted the E: entry and the corresponding ?? entry as well.
    After a reboot no change
    Still internal error in the windows disk management; mounted with paragon, the drive if accessible but I still cannot run chkdsk on it, or create a network share with it. Error: drive does not exist. Since this was my network storage, this is worse than having to remount it after every reboot.
    Any other ideas? (Or do you still want me to delete all keys?)
  7. #7
    Administrator
    06.11.2002
    2,044
    You can try delete all these keys. If needed you can reassign letters for your drives later.
    Also DAEMON Tools is not cause of your problem - we never change letters from other drives or delete them.
    Most likely it is related to other filter driver in your system which changed something in system when new drives appeared and now these changes are persistent even after DT removal.
  8. #8
    27.09.2005
    822
    actually, what happens if you start windows in safemode (pressing esc to stop sptd from loading).. does the drive re-appear then?
  9. #9
    08.06.2010
    9
    Quote Originally Posted by evlncrn8 View Post
    sptd is not installed anymore. i also checked that its files are deleted. so i don't need to try this, right? (for safemode i had to attach a screen and keyboard...)
  10. #10
    08.06.2010
    9
    The problem still exists. I have no idea and the strong feeling I have to reinstall windows. I don't want to believe that!
Tags for this Thread
