Showing results 1 to 3 of 3
Thread: BD-ROM Image
    07.06.2010
    2
    Default BD-ROM Image
    Hi,
    Previously with trial version I can work with my personal BD-ROM images, worked with images by mounting on the virtual drive like compressing the discs to save disc space on the hard drive. Then I had purchased the paid license. Now on the main interface I can see the iso images which are mounted on the drive but in windows explorer I cannot see the disc and windows says it could not read the disk as the format is unknown or corrupted. Now I donot know why this is happening.
    Any suggestions? Or Protection on the disc image which is creating the problems, but actually I removed the protection using another software.
    07.06.2010
    2
    Actually the file system showing in Main Page of Daemon Tools Pro main page is UDF.
    Does that make any difference?
    Are you using Windows XP?
