Showing results 1 to 2 of 2
Thread: Daemon installer disappears
    Ausrufezeichen Daemon installer disappears
    Hello, For quite some time I am unable to install Daemon tools: the installer just disappears after I accept the EULA. I have tried installing, reinstalling, removing SPDT files (registry and driver file) and nothing seems to solve the problem. I am using Windows 7 (Home Premium), with AVG antivirus software and COMODO firewall. Same system configuration on PC and laptop and only on laptop there is a problem. I suspect it might have something to do with the SPDT update, or previous copy of daemon tools still being present in the system registry. Plz help!
    Also I have tried different installers, but that did not solve the problem.
    Please disable D+ defense in Comodo completely (there is an option which requires a reboot and that option must be unchecked), reboot then and try again.
