Showing results 1 to 6 of 6
Thread: Please insert the original disk instead of a backup
    Default Please insert the original disk instead of a backup
    When trying to run my disk image in Daemon Tools Lite I get the error "Please insert the original disk instead of a backup" I have purchased this game, I just like playing without the disk as my drive can be noisy and I would like to avoid the disk getting scratched.
    I know this problem has been mentioned before, I have read previous threads and it has been mentiioned that using the securom profile on Daemon Tools Pro, will get past this problem, I was just wondering if this is still the case, or would I be wasting my time by purchasing Daemon Tools Pro.
    thanks,
    That's still the case you need to create an image with DT Pro and SecuROM profile.
    Thankyou for your reply
    Sorry 1 more thing, will I also need Daemon Tools Pro to run the image or only to create it?
  5. #5
    Customer Terramex's Avatar
    06.09.2004
    2,566
    The vast majority of SecuROM versions does also work in the virtual SCSI drive of DAEMON Tools lite.
  6. #6
    Thanks, ill give it a go.
