Showing results 1 to 6 of 6
Thread: SPTD Version: None Installed
    Default SPTD Version: None Installed
    I'm attempting to use the advanced emulation features of Daemon Tools Pro Advanced but the program claims I will need to install SPTD drivers. When I try to let the program do this, it restarts the machine, attempts and silently fails. The program claims it is installing the drivers when it reboots but after a few minutes it stops and nothing happens. Going back into Daemon Tools pro and attempting to create a new SCIS or IDE drive results in the same message.
    I have also tried both manually uninstalling the drivers, removing Daemon Tools and installing them though the SPTD site's own installer but the results are the same. Clicking the about button tells me this:
    I've managed to run though this several times, each in a different order but nothing seems to change. Somehow it looks like SPTD drivers are fine yet Daemon tools is unable to detect them.
    I searched the forums and saw somewhat similar problems but they're not quiet the same as what I'm experiencing. It doesn't appear my anti-virus (MSE) has anything to do with this problem.
    Currently i'm using Windows 7, 64 bit Edition. Does anyone have any solutions for this?
    Customer Terramex's Avatar
    06.09.2004
    2,566
    Please attach/upload a zipped Autoruns arn file (no installation required).
    The Autoruns.exe has given me this file. I placed it into a .zip archive and attached it.
    AutoRuns.zip
    Please try to deactivate Spybot completely and then try again.
    06.09.2004
    2,566
    In addition:
    maybe it's enough to just disable the Live Protection Background Service as reported in these threads.
    http://forum.daemon-tools.cc/f19/mos...04/#post134611
    http://forum.daemon-tools.cc/f19/can...tml#post133596
  6. #6
    Uninstalling spybot search and destroy immediately let Daemon Tools recognize the SPTD drivers. Mounting a virtual IDE driver worked fine but attempting to mount a SCSI driver would simply fail silently until I restarted. Now everything appears to work fine. I had no idea Spybot would conflict with this software.
    Thanks a lot, Blazkowicz and Terramex!
Tags for this Thread
