Showing results 21 to 30 of 42
Thread: Discussion: DAEMON Tools & MountSpace service
  1. #21
    Loony User
    artman's Avatar
    17.06.2010
    8
    @WithinRafael
    Image hash is being generated based on an image file itself. For example if you and I have the same image file, our image hashes will be equal.
    This hash is sent just to get information about your image and show it to you in MountSpace panel.
    Mountspace though has to determine unique users to get correct statistics. There is an ID value in registry in HKEY_CURRENT_USER\Software\DT Soft\DAEMON Tools Pro(Lite)\MountSpace. I can assure you that this ID is randomly generated on server without any algorithms that include your personal information..
    So there is no way to identify you.
    Errare humanum est...
  2. #22
    Quote Originally Posted by artman View Post
    @WithinRafael
    Servers logs could easily contain the hash/IP I submitted. Again, they may say they don't store this data, but we have no way to verify this. There's nothing in the privacy policy. Understand?
  3. #23
    Loony User
    artman's Avatar
    17.06.2010
    8
    @WithinRafael
    I'm sure that privacy policy will be created asap)
    do you think google or facebook aren't saving your IPs?)) they have have all your secrets comparing to image filename )
  4. #24
    28.10.2005
    322
    It doesn´t matter what other companies do. That can´t be used as an argument that the possibility of storing data isn´t that bad.
  5. #25
    Master
    Sway's Avatar
    09.07.2009
    1,966
    As I already said we DO NOT store IP addresses or any other information which can be used to identify you.
    Moreover, we DO NOT want you to have any problems because of DAEMON Tools & MountSpace. Do you really think it is profitable for us??? Security is one of the main requirements to MountSpace service.
    MountSpace usage (sending statistics and getting info from MountSpace.com) is absolutely optional. If you thus don't trust us, just disable appropriate options in your DAEMON Tools program. That's all!
    We work on creating the most convenient and useful service for you. So we appreciate any constructive feedback.
    P.S. Encrypting of requests to MountSpace.com will be implemented in the nearest time.
  6. #26
    Master
    Sway's Avatar
    09.07.2009
    1,966
    Hi all!
    MountSpace.com has been updated today
    Now widget and MountSpace server interact via SSL. So there is no possibility to intercept data sent from/to a user.
  7. #27
    Quote: "MountSpace usage (sending statistics and getting info from MountSpace.com) is absolutely optional. If you thus don't trust us, just disable appropriate options in your DAEMON Tools program. That's all!"
    Could you please explain exactly to disable these options? I thought I had disabled it but immediately upon launch my firewall detects DT trying to make a connection. I shouldn't have to block it with a firewall.
  8. #28
    UKRAINIAN TRANSLATOR OFFICIAL TRANSLATOR
    oder2's Avatar
    29.09.2005
    368
    DT might be trying to make a license check on start. Are you sure it tried to connect to MountSpace?
  9. #29
    Mind's Avatar
    27.11.2007
    25
    If possible, please remove this service in a paid version of daemon tools. Thanks in advance.
  10. #30
    Customer Terramex's Avatar
    06.09.2004
    2,566
    @Mind
    I can't act as a spokesman for the devs; just asking: you are aware you can completely
    deactivate all Mountspace functions in Preferences/Media info tab at point 1 and 3 ?
