Showing results 1 to 4 of 4
Thread: Unable to open, upgrade or uninstall DTLite
    Default Unable to open, upgrade or uninstall DTLite
    When I try to open the software I receive a popup box saying Error: core library wasn't found.
    I tried to upgrade to the latest version but it just says it was unable to uninstall the old version.
    When I try a manual uninstall I just get a box that says 1
    Any suggestions?
    Master
    Sway's Avatar
    09.07.2009
    1,966
    Please specify your OS and DAEMON Tools version/
    Do you have SPTD driver installed?
    Windows XP
    Is there any way of telling the DT version without opening the software?
    It would have been a default install some months ago. Is there any other way of determining if SPTD is installed?
    Master
    Sway's Avatar
    09.07.2009
    1,966
    Quote Originally Posted by crimsonstorm View Post
    Please find dtlite.exe or daemon.exe file -> right click on it -> Properties -> Details tab -> Product version.
    Download appropriate installation file from DuplexSecure - Downloads and run it. In case SPTD already installed, you will get message that SPTD was detected.
