Showing results 1 to 6 of 6
Thread: NWN Hordes of the Underdark
    Default NWN Hordes of the Underdark
    Operating System: WinXP
    Burning Software: CloneCD 3.3.4.1
    Anti-virus Software: (trying to slide with nothing for the time being)
    DAEMON Tools Version: 3.46
    Seems DAEMON Tools doesn't fool the copy protection on the latest in the NWN expansion series. *sigh*
    HoTU recognizes my Stealth DVD as a copy and sends me to the SecuROM site for details (their way of gloating, I imagine. :roll: )
    Any help here?
    I guess in the meantime, I'll keep causing wear and tear on my expensive CD.... :x
    Your CloneCD version is probably blacklisted, try to disable hide ATIP function/tray, and/or to un-install CloneCD.
    Also be sure to use image with DPM data (e.g. Alcohol or Blindwrite), CloneCD image won't work!
    10.07.2004
    2
    Operating System: winxp
    Burning Software: disc juggler,alchohol 120,nero 6.3
    Anti-virus Software: mcav not sure which version
    DAEMON Tools Version: 3.33
    this happenswith all securom games, they detect that daemon is running . perimeter is another example. when you attempt to run it it says emulation software detected and refers you to securom/emulation. what do theadmins reccommend we do
    You should try v3.46 :mrgreen: 3.33 is outdated :idea:
  5. #5
    10.07.2004
    2
    nope an update doesnt help. I think they blacklisted D-Tools
  6. #6
    Which update version do you use? Did you try to un-install CloneCD?
