Instellation Issue 25032 (0x61c8), 0 (0x0)
  • Instellation Issue 25032 (0x61c8), 0 (0x0)
    Operating System: Windows 98
    Burning Software: Nti
    Anti-virus Software: Norton 2000 pro
    DAEMON Tools Version: DAEMON Tools 3.46\daemon.msi
    i am having trouble installing your softwear.. i logged the install and here is the results.. i also get this error code.. 25032 (0x61c8), 0 (0x0)
    Please let me know what i need to do to fix this issue.. thanks
    here is log
    === Verbose logging started: 07/25/2004 17:06:53 Build type: SHIP ANSI 2.00.2600.02 Calling process: C:\WINDOWS\SYSTEM\MSIEXEC.EXE ===
    MSI (c) (67:97): Resetting cached policy values
    MSI (c) (67:97): Machine policy value 'Debug' is 0
    MSI (c) (67:97): ******* RunEngine:
    ******* Product: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\daemon.msi
    ******* Action:
    ******* CommandLine: **********
    MSI (c) (67:97): End dialog not enabled
    MSI (c) (67:97): Original package ==> C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\daemon.msi
    MSI (c) (67:97): Package we're running from ==> C:\windows\TEMP\529ea.msi
    MSI (c) (67:97): APPCOMPAT: looking for appcompat database entry with ProductCode '{56CA5D3B-3002-4E7B-90FE-071D8FDF3814}'.
    MSI (c) (67:97): APPCOMPAT: no matching ProductCode found in database.
    MSI (c) (67:97): Machine policy value 'TransformsSecure' is 0
    MSI (c) (67:97): User policy value 'TransformsAtSource' is 0
    MSI (c) (67:97): Transforms are not secure.
    MSI (c) (67:97): Command Line: REINSTALLMODE=vemus CURRENTDIRECTORY=C:\ CLIENTUILEVEL=0 CLIENTPROCESSID=-3606425
    MSI (c) (67:97): Product Code passed to Engine.Initialize: ''
    MSI (c) (67:97): Product Code from property table before transforms: '{56CA5D3B-3002-4E7B-90FE-071D8FDF3814}'
    MSI (c) (67:97): Product Code from property table after transforms: '{56CA5D3B-3002-4E7B-90FE-071D8FDF3814}'
    MSI (c) (67:97): Product not registered: beginning first-time install
    MSI (c) (67:97): Entering CMsiConfigurationManager::SetLastUsedSource.
    MSI (c) (67:97): User policy value 'SearchOrder' is 'nmu'
    MSI (c) (67:97): Adding new sources is allowed.
    MSI (c) (67:97): Package name extracted from package path: 'daemon.msi'
    MSI (c) (67:97): Package to be registered: 'daemon.msi'
    MSI (c) (67:97): Note: 1: 2729
    MSI (c) (67:97): Note: 1: 2262 2: AdminProperties 3: -2147287038
    MSI (c) (67:97): Machine policy value 'DisableMsi' is 0
    MSI (c) (67:97): Machine policy value 'AlwaysInstallElevated' is 0
    MSI (c) (67:97): User policy value 'AlwaysInstallElevated' is 0
    MSI (c) (67:97): Running product '{56CA5D3B-3002-4E7B-90FE-071D8FDF3814}' with user privileges: It's not assigned.
    MSI (c) (67:97): TRANSFORMS property is now:
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Application Data
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Favorites
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\NetHood
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\My Documents
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\PrintHood
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Recent
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\SendTo
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\ShellNew
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\All Users\Application Data
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Local Settings\Application Data
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\My Documents\My Pictures
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Start Menu\Programs\Administrative Tools
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Start Menu\Programs\StartUp
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\Desktop
    MSI (c) (67:97): SHFOLDER::SHGetFolderPath returned: C:\WINDOWS\FONTS
    MSI (c) (67:97): Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
    MSI (c) (67:97): MSCOREE not loaded loading copy from system32
    MSI (c) (67:97): Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
    === Logging started: 07/25/2004 17:06:54 ===
    MSI (c) (67:97): Machine policy value 'DisableRollback' is 0
    MSI (c) (67:97): User policy value 'DisableRollback' is 0
    MSI (c) (67:97): Doing action: INSTALL
    MSI (c) (67:97): Note: 1: 2262 2: ActionText 3: -2147287038
    Action start 17:06:54: INSTALL.
    MSI (c) (67:97): UI Sequence table 'InstallUISequence' is present and populated.
    MSI (c) (67:97): Running UISequence
    MSI (c) (67:97): Doing action: DaemonFindRelatedProducts
    Action start 17:06:54: DaemonFindRelatedProducts.
    MSI (c) (67:97): Creating MSIHANDLE (1) of type 790542 for thread -3618153
    Action ended 17:06:54: DaemonFindRelatedProducts. Return value 1.
    MSI (c) (67:97): Skipping action: ERRCA_CANCELNEWERVERSION (condition is false)
    MSI (c) (67:97): Doing action: LaunchConditions
    Action start 17:06:54: LaunchConditions.
    MSI (c) (67:97): Note: 1: 2262 2: LaunchCondition 3: -2147287038
    Action ended 17:06:54: LaunchConditions. Return value 1.
    MSI (c) (67:97): Doing action: SetAllUsers
    Action start 17:06:54: SetAllUsers.
    Action ended 17:06:54: SetAllUsers. Return value 1.
    MSI (c) (67:97): Doing action: ValidateProductID
    Action start 17:06:54: ValidateProductID.
    Action ended 17:06:55: ValidateProductID. Return value 1.
    MSI (c) (67:97): Doing action: DIRCA_TARGETDIR
    Action start 17:06:55: DIRCA_TARGETDIR.
    Action ended 17:06:55: DIRCA_TARGETDIR. Return value 1.
    MSI (c) (67:97): Doing action: CostInitialize
    Action start 17:06:55: CostInitialize.
    Action ended 17:06:55: CostInitialize. Return value 1.
    MSI (c) (67:97): Doing action: FileCost
    Action start 17:06:55: FileCost.
    MSI (c) (67:97): Note: 1: 2205 2: 3: MsiAssembly
    MSI (c) (67:97): Note: 1: 2205 2: 3: Class
    MSI (c) (67:97): Note: 1: 2205 2: 3: Extension
    MSI (c) (67:97): Note: 1: 2205 2: 3: TypeLib
    MSI (c) (67:97): Note: 1: 2262 2: MoveFile 3: -2147287038
    MSI (c) (67:97): Note: 1: 2262 2: DuplicateFile 3: -2147287038
    Action ended 17:06:55: FileCost. Return value 1.
    MSI (c) (67:97): Skipping action: ResumeForm (condition is false)
    MSI (c) (67:97): Skipping action: MaintenanceForm (condition is false)
    MSI (c) (67:97): Doing action: CostFinalize
    Action start 17:06:55: CostFinalize.
    MSI (c) (67:97): Note: 1: 2262 2: Patch 3: -2147287038
    MSI (c) (67:97): Note: 1: 2262 2: Condition 3: -2147287038
    MSI (c) (67:97): Target path resolution complete. Dumping Directory table...
    MSI (c) (67:97): Note: target paths subject to change (via custom actions or browsing)
    MSI (c) (67:97): Dir (target): Key: TARGETDIR , Object: C:\Program Files\D-Tools\
    MSI (c) (67:97): Dir (target): Key: _AA5686DBB87B4B8FA4E3ACB6086EB296 , Object: C:\Program Files\D-Tools\Lang\
    MSI (c) (67:97): Dir (target): Key: DesktopFolder , Object: C:\WINDOWS\Desktop\
    MSI (c) (67:97): Dir (target): Key: _49873D75A85B41A09DCF67EC24FD49F5 , Object: C:\Program Files\D-Tools\Help\
    MSI (c) (67:97): Dir (target): Key: _200FF33CDAF641D48F563024F8575E12 , Object: C:\Program Files\D-Tools\Plugins\
    MSI (c) (67:97): Dir (target): Key: _FFB3C6D21DA04C19B88373AD3A9EEE74 , Object: C:\Program Files\D-Tools\Plugins\Images\
    MSI (c) (67:97): Dir (target): Key: WindowsFolder , Object: C:\WINDOWS\
    MSI (c) (67:97): Dir (target): Key: _6B0531DAE1374020804041239DD86170 , Object: C:\WINDOWS\All Users\
    MSI (c) (67:97): Dir (target): Key: _821996B0BCC2468AB6A912B9678B2ED2 , Object: C:\WINDOWS\All Users\Desktop\
    MSI (c) (67:97): Dir (target): Key: _0636CC14F5B7426CA2D3F0BBC7C874C8 , Object: C:\WINDOWS\SYSTEM32\
    MSI (c) (67:97): Dir (target): Key: _71BE3D3665624B77B7D179FFA0034F32 , Object: C:\WINDOWS\SYSTEM32\Drivers\
    MSI (c) (67:97): Dir (target): Key: _3AEFD1B6282A45388F879BD563581133 , Object: C:\Program Files\D-Tools\Icons\
    MSI (c) (67:97): Dir (target): Key: SystemFolder , Object: C:\WINDOWS\SYSTEM\
    MSI (c) (67:97): Dir (target): Key: _B1B6EFB296EE48A5B85DF07446A36372 , Object: C:\WINDOWS\SYSTEM\IOSUBSYS\
    MSI (c) (67:97): Note: 1: 2228 2: 3: MsiAssembly 4: SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`, `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE `MsiAssembly`.`Component_` = `Component
    `.`Component` AND `MsiAssembly`.`Component_` = ?
    Action ended 17:06:55: CostFinalize. Return value 1.
    MSI (c) (67:97): Doing action: WelcomeForm
    Action start 17:06:55: WelcomeForm.
    Info 2898. VSI_MS_Sans_Serif13.0_0_0, MS Sans Serif, 0
    Info 2898. VsdDefaultUIFont.524F4245_5254_5341_4C45_534153783 400, MS Sans Serif, 0
    Info 2898. VSI_MS_Sans_Serif16.0_1_0, MS Sans Serif, 0
    Action 17:06:55: WelcomeForm. Dialog created
    Action 17:06:59: FolderForm. Dialog created
    Action start 17:07:01: DaemonFindRelatedProducts.
    Action ended 17:07:01: DaemonFindRelatedProducts. Return value 1.
    Action 17:07:01: ConfirmInstallForm. Dialog created
    Action ended 17:07:02: WelcomeForm. Return value 1.
    MSI (c) (67:97): Doing action: ProgressForm
    Action start 17:07:02: ProgressForm.
    Action 17:07:03: ProgressForm. Dialog created
    Action ended 17:07:03: ProgressForm. Return value 1.
    MSI (c) (67:97): Doing action: ExecuteAction
    Action start 17:07:03: ExecuteAction.
    MSI (c) (67:97): Grabbed execution mutex.
    MSI (c) (67:97): Incrementing counter to disable shutdown. Counter after increment: 0
    MSI (c) (67:97): Not switching to server: we're not connected to the server
    Action start 17:07:03: INSTALL.
    MSI (c) (67:97): Running ExecuteSequence
    Action start 17:07:03: DaemonFindRelatedProducts.
    MSI (c) (67:97): Skipping action due to msidbCustomActionTypeFirstSequence option.
    Action ended 17:07:03: DaemonFindRelatedProducts. Return value 0.
    Action start 17:07:03: LaunchConditions.
    Action ended 17:07:03: LaunchConditions. Return value 1.
    Action start 17:07:03: SetAllUsers.
    Action ended 17:07:03: SetAllUsers. Return value 1.
    Action start 17:07:03: ValidateProductID.
    Action ended 17:07:03: ValidateProductID. Return value 1.
    MSI (c) (67:97): Skipping action: DIRCA_TARGETDIR (condition is false)
    Action start 17:07:03: CostInitialize.
    MSI (c) (67:97): Skipping CostInitialize: action already run in this engine.
    Action ended 17:07:03: CostInitialize. Return value 0.
    Action start 17:07:03: FileCost.
    MSI (c) (67:97): Skipping FileCost: action already run in this engine.
    Action ended 17:07:03: FileCost. Return value 0.
    Action start 17:07:03: CostFinalize.
    MSI (c) (67:97): Skipping CostFinalize: action already run in this engine.
    Action ended 17:07:03: CostFinalize. Return value 0.
    MSI (c) (67:97): Doing action: InstallValidate
    Action start 17:07:03: InstallValidate.
    MSI (c) (67:97): Feature: DefaultFeature; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: __C__AD1BBC6C97136594B89931DE25DC2BA165; Installed: Null; Request: Local; Action: Local
    MSI (c) (67:97): Component: __C__64A010FFCA674912AE56819F8E86917965; Installed: Null; Request: Local; Action: Local
    MSI (c) (67:97): Component: __C__5B6A3D472008842B045A0ECC20D12C5868; Installed: Null; Request: Local; Action: Local
    MSI (c) (67:97): Component: __C__5B6A3D472008842B045A0ECC20D12C5867; Installed: Null; Request: Local; Action: Local
    MSI (c) (67:97): Component: __C__5B6A3D472008842B045A0ECC20D12C5866; Installed: Null; Request: Local; Action: Local
    MSI (c) (67:97): Component: __C__5B6A3D472008842B045A0ECC20D12C5865; Installed: Null; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__1A9AF1CF76D44CEEB4939794A59A4F54; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__49261909BC5A4E379F95509D8C69DCC2; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__A7BDB994C34D418D88EFFA78D86ED008; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__A9FE412ECDC542C189F46DC3A07DE664; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__AB1F207C755D41E481F0CF3E6FFE7B74; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__DFEDEE2798614FF5999E1653431C6EEF; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__E08399B558BF4C58B85DFF7D3EF4FF54; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__ECBEEF91A26B49AA90323A0C95ECAE70; Installed: Absent; Request: Local; Action: Null
    MSI (c) (67:97): Component: C__64A010FFCA674912AE56819F8E869179; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__AD1BBC6C97136594B89931DE25DC2BA1; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__5B6A3D472008842B045A0ECC20D12C58; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__23E711B4C2014BEF63E7D32A5BE5F0F0; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__05F6F4B02A8D4DA59F8FE1E074DBC461; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__C1427C2E823BA8FD54C6128B345EC95B; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__6728973B34FE42F3E90D17B2EC4709FB; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Component: C__622411564CD4AE4C6843CC5218F69322; Installed: Absent; Request: Local; Action: Local
    MSI (c) (67:97): Note: 1: 2205 2: 3: BindImage
    MSI (c) (67:97): Note: 1: 2205 2: 3: ProgId
    MSI (c) (67:97): Note: 1: 2205 2: 3: PublishComponent
    MSI (c) (67:97): Note: 1: 2205 2: 3: SelfReg
    MSI (c) (67:97): Note: 1: 2262 2: Font 3: -2147287038
    MSI (c) (67:97): Note: 1: 2205 2: 3: #_PatchCache
    MSI (c) (67:97): Note: 1: 2228 2: 3: #_PatchCache 4: SELECT `TempCopy` FROM `#_PatchCache` ORDER BY `Sequence`
    MSI (c) (67:97): Note: 1: 2727 2:
    Action ended 17:07:03: InstallValidate. Return value 1.
    MSI (c) (67:97): Doing action: RemoveExistingProducts
    Action start 17:07:03: RemoveExistingProducts.
    Action ended 17:07:03: RemoveExistingProducts. Return value 1.
    MSI (c) (67:97): Doing action: DaemonInstallValidate
    Action start 17:07:03: DaemonInstallValidate.
    MSI (c) (67:97): Creating MSIHANDLE (3) of type 790542 for thread -3618153
    Action ended 17:07:03: DaemonInstallValidate. Return value 1.
    MSI (c) (67:97): Doing action: InstallInitialize
    Action start 17:07:03: InstallInitialize.
    MSI (c) (67:97): BeginTransaction: Locking Server
    MSI (c) (67:97): Server not locked: locking for product {56CA5D3B-3002-4E7B-90FE-071D8FDF3814}
    Action ended 17:07:03: InstallInitialize. Return value 1.
    MSI (c) (67:97): Skipping action: ForceReboot (condition is false)
    MSI (c) (67:97): Doing action: DaemonSetPath1
    Action start 17:07:03: DaemonSetPath1.
    Action ended 17:07:03: DaemonSetPath1. Return value 1.
    MSI (c) (67:97): Doing action: DaemonSetPath2
    Action start 17:07:03: DaemonSetPath2.
    Action ended 17:07:03: DaemonSetPath2. Return value 1.
    MSI (c) (67:97): Doing action: AllocateRegistrySpace
    Action start 17:07:03: AllocateRegistrySpace.
    Action ended 17:07:03: AllocateRegistrySpace. Return value 1.
    MSI (c) (67:97): Doing action: ProcessComponents
    Action start 17:07:03: ProcessComponents.
    MSI (c) (67:97): Resolving source.
    MSI (c) (67:97): Resolving source to launched-from source.
    MSI (c) (67:97): Setting launched-from source as last-used.
    MSI (c) (67:97): SOURCEDIR ==> C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\
    MSI (c) (67:97): SOURCEDIR product ==> {56CA5D3B-3002-4E7B-90FE-071D8FDF3814}
    MSI (c) (67:97): Determining source type
    MSI (c) (67:97): Source type from package 'daemon.msi': 2
    MSI (c) (67:97): Source path resolution complete. Dumping Directory table...
    MSI (c) (67:97): Dir (source): Key: TARGETDIR , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: , ShortSubPath:
    MSI (c) (67:97): Dir (source): Key: _AA5686DBB87B4B8FA4E3ACB6086EB296 , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: Lang\ , ShortSubPath: LANG\
    MSI (c) (67:97): Dir (source): Key: DesktopFolder , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: User's Desktop\ , ShortSubPath: USER'S~1\
    MSI (c) (67:97): Dir (source): Key: _49873D75A85B41A09DCF67EC24FD49F5 , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: Help\ , ShortSubPath: HELP\
    MSI (c) (67:97): Dir (source): Key: _200FF33CDAF641D48F563024F8575E12 , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: Plugins\ , ShortSubPath: PLUGINS\
    MSI (c) (67:97): Dir (source): Key: _FFB3C6D21DA04C19B88373AD3A9EEE74 , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: Plugins\Images\ , ShortSubPath: PLUGINS\IMAGES\
    MSI (c) (67:97): Dir (source): Key: WindowsFolder , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: Windows Folder\ , ShortSubPath: WINDOW~1\
    MSI (c) (67:97): Dir (source): Key: _6B0531DAE1374020804041239DD86170 , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: Windows Folder\All Users\ , ShortSubPath: WINDOW~1\ALLUSE~1\
    MSI (c) (67:97): Dir (source): Key: _821996B0BCC2468AB6A912B9678B2ED2 , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: Windows Folder\All Users\Desktop\ , ShortSubPath: WINDOW~1\ALLUSE~1\DESKTOP\
    MSI (c) (67:97): Dir (source): Key: _0636CC14F5B7426CA2D3F0BBC7C874C8 , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: Windows Folder\SYSTEM32\ , ShortSubPath: WINDOW~1\SYSTEM32\
    MSI (c) (67:97): Dir (source): Key: _71BE3D3665624B77B7D179FFA0034F32 , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: Windows Folder\SYSTEM32\Drivers\ , ShortSubPath: WINDOW~1\SYSTEM32\DRIVERS\
    MSI (c) (67:97): Dir (source): Key: _3AEFD1B6282A45388F879BD563581133 , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: Icons\ , ShortSubPath: ICONS\
    MSI (c) (67:97): Dir (source): Key: SystemFolder , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: System Folder\ , ShortSubPath: SYSTEM~1\
    MSI (c) (67:97): Dir (source): Key: _B1B6EFB296EE48A5B85DF07446A36372 , Object: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\ , LongSubPath: System Folder\IOSUBSYS\ , ShortSubPath: SYSTEM~1\IOSUBSYS\
    Action 17:07:04: GenerateScript. Generating script operations for action:
    GenerateScript: Updating component registration
    Action ended 17:07:04: ProcessComponents. Return value 1.
    MSI (c) (67:97): Doing action: UnpublishFeatures
    Action start 17:07:04: UnpublishFeatures.
    Action ended 17:07:04: UnpublishFeatures. Return value 1.
    MSI (c) (67:97): Doing action: UnregisterFonts
    Action start 17:07:04: UnregisterFonts.
    Action ended 17:07:04: UnregisterFonts. Return value 1.
    MSI (c) (67:97): Doing action: RemoveRegistryValues
    Action start 17:07:04: RemoveRegistryValues.
    GenerateScript: Removing system registry values
    Action ended 17:07:04: RemoveRegistryValues. Return value 1.
    MSI (c) (67:97): Doing action: RemoveShortcuts
    Action start 17:07:04: RemoveShortcuts.
    Action ended 17:07:04: RemoveShortcuts. Return value 1.
    MSI (c) (67:97): Doing action: RemoveDuplicateFiles
    Action start 17:07:04: RemoveDuplicateFiles.
    Action ended 17:07:04: RemoveDuplicateFiles. Return value 1.
    MSI (c) (67:97): Doing action: RemoveFiles
    Action start 17:07:04: RemoveFiles.
    Action ended 17:07:04: RemoveFiles. Return value 1.
    MSI (c) (67:97): Doing action: RemoveFolders
    Action start 17:07:04: RemoveFolders.
    MSI (c) (67:97): Note: 1: 2262 2: CreateFolder 3: -2147287038
    Action ended 17:07:04: RemoveFolders. Return value 1.
    MSI (c) (67:97): Doing action: CreateFolders
    Action start 17:07:04: CreateFolders.
    Action ended 17:07:04: CreateFolders. Return value 1.
    MSI (c) (67:97): Doing action: MoveFiles
    Action start 17:07:04: MoveFiles.
    Action ended 17:07:04: MoveFiles. Return value 1.
    MSI (c) (67:97): Doing action: InstallFiles
    Action start 17:07:04: InstallFiles.
    GenerateScript: Copying new files
    MSI (c) (67:97): Note: 1: 2205 2: 3: MsiPatchOldAssemblyFile
    MSI (c) (67:97): Note: 1: 2228 2: 3: MsiPatchOldAssemblyFile 4: SELECT `MsiPatchOldAssemblyFile`.`Assembly_` FROM `MsiPatchOldAssemblyFile` WHERE `MsiPatchOldAssemblyFile`.`File_` = ?
    MSI (c) (67:97): Note: 1: 2262 2: MsiPatchHeaders 3: -2147287038
    Action ended 17:07:04: InstallFiles. Return value 1.
    MSI (c) (67:97): Doing action: PatchFiles
    Action start 17:07:04: PatchFiles.
    Action ended 17:07:04: PatchFiles. Return value 1.
    MSI (c) (67:97): Doing action: DuplicateFiles
    Action start 17:07:04: DuplicateFiles.
    Action ended 17:07:04: DuplicateFiles. Return value 1.
    MSI (c) (67:97): Doing action: CreateShortcuts
    Action start 17:07:04: CreateShortcuts.
    MSI (c) (67:97): Note: 1: 2770 2: 47
    MSI (c) (67:97): Note: 1: 2770 2: 24
    MSI (c) (67:97): Note: 1: 2770 2: 23
    MSI (c) (67:97): Note: 1: 2770 2: 22
    MSI (c) (67:97): Note: 1: 2770 2: 25
    GenerateScript: Creating shortcuts
    Action ended 17:07:04: CreateShortcuts. Return value 1.
    MSI (c) (67:97): Doing action: WriteRegistryValues
    Action start 17:07:04: WriteRegistryValues.
    GenerateScript: Writing system registry values
    Action ended 17:07:04: WriteRegistryValues. Return value 1.
    MSI (c) (67:97): Doing action: RegisterFonts
    Action start 17:07:04: RegisterFonts.
    Action ended 17:07:04: RegisterFonts. Return value 1.
    MSI (c) (67:97): Doing action: RegisterUser
    Action start 17:07:04: RegisterUser.
    Action ended 17:07:04: RegisterUser. Return value 1.
    MSI (c) (67:97): Doing action: RegisterProduct
    Action start 17:07:04: RegisterProduct.
    GenerateScript: Registering product
    Action ended 17:07:04: RegisterProduct. Return value 1.
    MSI (c) (67:97): Doing action: PublishFeatures
    Action start 17:07:04: PublishFeatures.
    GenerateScript: Publishing Product Features
    Action ended 17:07:04: PublishFeatures. Return value 1.
    MSI (c) (67:97): Doing action: PublishProduct
    Action start 17:07:04: PublishProduct.
    GenerateScript: Publishing product information
    MSI (c) (67:97): Note: 1: 2228 2: 3: #_PatchCache 4: SELECT `PatchId`, `PackageName`, `SourceList`, `TransformList`, `TempCopy`, `Existing`, `Unregister`, `SourcePath` FROM `#_PatchCache` ORDER BY `Sequence`
    Action ended 17:07:04: PublishProduct. Return value 1.
    MSI (c) (67:97): Skipping action: DaemonDriverUninstall (condition is false)
    MSI (c) (67:97): Skipping action: DaemonRemoveDrives (condition is false)
    MSI (c) (67:97): Doing action: SetDrvInstallIndex
    Action start 17:07:04: SetDrvInstallIndex.
    Action ended 17:07:04: SetDrvInstallIndex. Return value 1.
    MSI (c) (67:97): Doing action: DaemonDriverInstall
    Action start 17:07:04: DaemonDriverInstall.
    GenerateScript: DaemonDriverInstall
    Action ended 17:07:04: DaemonDriverInstall. Return value 1.
    MSI (c) (67:97): Doing action: ScheduleReboot
    Action start 17:07:04: ScheduleReboot.
    Action ended 17:07:04: ScheduleReboot. Return value 1.
    MSI (c) (67:97): Doing action: DaemonDuplicateShortcut
    Action start 17:07:04: DaemonDuplicateShortcut.
    GenerateScript: DaemonDuplicateShortcut
    Action ended 17:07:04: DaemonDuplicateShortcut. Return value 1.
    MSI (c) (67:97): Skipping action: DaemonRemoveShortcut (condition is false)
    MSI (c) (67:97): Doing action: InstallFinalize
    Action start 17:07:04: InstallFinalize.
    MSI (c) (67:97): Running Script: c:\windows\TEMP\MSI7040.TMP
    MSI (c) (67:97): Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Installer\Rollback\Scripts 3: 2
    MSI (c) (67:97): Executing op: Header(Signature=1397708873,Version=200,Timestamp= 821659874,LangId=1033,Platform=0,ScriptType=1,Scri ptMajorVersion=21,ScriptMinorVersion=4,ScriptAttri butes=0)
    MSI (c) (67:97): Executing op: ProductInfo(ProductKey={56CA5D3B-3002-4E7B-90FE-071D8FDF3814},ProductName=DAEMON Tools,PackageName=daemon.msi,Language=1033,Version =53346304,Assignment=1,ObsoleteArg=0,ProductIcon=_ daemoncp.exe,,PackageCode={75AC544C-C2F2-45
    F1-991F-8AC6CF687776},,)
    MSI (c) (67:97): Executing op: DialogInfo(Type=0,Argument=1033)
    MSI (c) (67:97): Executing op: DialogInfo(Type=1,Argument=DAEMON Tools)
    MSI (c) (67:97): Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDesc ription=Rolling back action:,RollbackTemplate=,CleanupAction=RollbackCl eanup,CleanupDescription=Removing backup files,CleanupTemplate=File: )
    MSI (c) (67:97): Executing op: ActionStart(Name=ProcessComponents,Description=Upd ating component registration,)
    Action 17:07:04: ProcessComponents. Updating component registration
    MSI (c) (67:97): Executing op: ProgressTotal(Total=16,Type=1,ByteEquivalent=24000 )
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={F1348A90-0D38-9878-52A2-45B8974E91B5},KeyPath=C:\WINDOWS\SYSTEM\IOSUBSYS\s tormprt.pdr,State=3,,Disk=1,SharedDllRefCount=0,Bi naryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {F1348A90-0D38-9878-52A2-45B8974E91B5} 3: C:\WINDOWS\SYSTEM\IOSUBSYS\stormprt.pdr
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={1F32440C-AD62-5C19-CE45-D4B3C6BE5042},KeyPath=C:\Program Files\D-Tools\Icons\tray1.ico,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {1F32440C-AD62-5C19-CE45-D4B3C6BE5042} 3: C:\Program Files\D-Tools\Icons\tray1.ico
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={3CB4FF4B-530C-EE06-71C0-C413467C5B3A},KeyPath=C:\WINDOWS\SYSTEM32\Drivers\ stormbus.sys,State=3,,Disk=1,SharedDllRefCount=0,B inaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {3CB4FF4B-530C-EE06-71C0-C413467C5B3A} 3: C:\WINDOWS\SYSTEM32\Drivers\stormbus.sys
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={14AF5BEF-9C47-662C-B6EA-157A22F32889},KeyPath=C:\Program Files\D-Tools\Plugins\Images\bw5mount.dll,State=3,,Disk=1, SharedDllRefCount=0,BinaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {14AF5BEF-9C47-662C-B6EA-157A22F32889} 3: C:\Program Files\D-Tools\Plugins\Images\bw5mount.dll
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={71694941-16DA-7B9A-CA7B-59027B7A7C9E},KeyPath=C:\Program Files\D-Tools\pfctoc.dll,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {71694941-16DA-7B9A-CA7B-59027B7A7C9E} 3: C:\Program Files\D-Tools\pfctoc.dll
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={58D45418-AF8F-C22D-9DFB-D30E0127288F},KeyPath=C:\Program Files\D-Tools\Icons\tray2.ico,State=3,,Disk=1,SharedDllRef Count=0,BinaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {58D45418-AF8F-C22D-9DFB-D30E0127288F} 3: C:\Program Files\D-Tools\Icons\tray2.ico
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={EBE86571-6CB3-FEDB-1931-C610BA103F8C},KeyPath=C:\Program Files\D-Tools\Help\1033.chm,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {EBE86571-6CB3-FEDB-1931-C610BA103F8C} 3: C:\Program Files\D-Tools\Help\1033.chm
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={DD00EF30-3BDE-8A93-BC88-9EB9BD5EB7DC},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {DD00EF30-3BDE-8A93-BC88-9EB9BD5EB7DC} 3:
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={2844603B-BF08-A866-5F41-3A9D8424FA3F},KeyPath=02:\Software\Microsoft\Windo ws\CurrentVersion\Run\DAEMON Tools-1033,State=3,,Disk=1,SharedDllRefCount=0,BinaryTyp e=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {2844603B-BF08-A866-5F41-3A9D8424FA3F} 3: 02:\Software\Microsoft\Windows\CurrentVersion\Run\ DAEMON Tools-1033
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={1B3C1FD5-E78C-73DF-5628-3F8A8BF1254D},KeyPath=C:\Program Files\D-Tools\daemon.exe,State=3,,Disk=1,SharedDllRefCount =0,BinaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {1B3C1FD5-E78C-73DF-5628-3F8A8BF1254D} 3: C:\Program Files\D-Tools\daemon.exe
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={4778E2F1-97F8-6760-FCE7-6F40133642E1},KeyPath=C:\WINDOWS\daemon.dll,State= 3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {4778E2F1-97F8-6760-FCE7-6F40133642E1} 3: C:\WINDOWS\daemon.dll
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={5C08F250-62DB-2420-DCCD-96D44A60F9AC},KeyPath=C:\Program Files\D-Tools\Plugins\Images\mdsmount.dll,State=3,,Disk=1, SharedDllRefCount=0,BinaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {5C08F250-62DB-2420-DCCD-96D44A60F9AC} 3: C:\Program Files\D-Tools\Plugins\Images\mdsmount.dll
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={D78D847A-FB9A-5CD4-9B58-E95D6FD66576},KeyPath=C:\Program Files\D-Tools\Plugins\Images\ccdmount.dll,State=3,,Disk=1, SharedDllRefCount=0,BinaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {D78D847A-FB9A-5CD4-9B58-E95D6FD66576} 3: C:\Program Files\D-Tools\Plugins\Images\ccdmount.dll
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={E9B007DD-A16F-79AE-BDA1-C1F91727F55B},KeyPath=C:\Program Files\D-Tools\Lang\1033.dll,State=3,,Disk=1,SharedDllRefCo unt=0,BinaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {E9B007DD-A16F-79AE-BDA1-C1F91727F55B} 3: C:\Program Files\D-Tools\Lang\1033.dll
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={CBAFD912-FDF7-92BD-D6B2-9672004DF049},KeyPath=C:\Program Files\D-Tools\Plugins\Images\nrgmount.dll,State=3,,Disk=1, SharedDllRefCount=0,BinaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {CBAFD912-FDF7-92BD-D6B2-9672004DF049} 3: C:\Program Files\D-Tools\Plugins\Images\nrgmount.dll
    MSI (c) (67:97): Executing op: ComponentRegister(ComponentId={59C4B8CC-4D42-EA20-2C2F-D725396B8701},KeyPath=C:\Program Files\D-Tools\Plugins\Images\pdimount.dll,State=3,,Disk=1, SharedDllRefCount=0,BinaryType=0)
    1: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 2: {59C4B8CC-4D42-EA20-2C2F-D725396B8701} 3: C:\Program Files\D-Tools\Plugins\Images\pdimount.dll
    MSI (c) (67:97): Executing op: ActionStart(Name=RemoveRegistryValues,Description= Removing system registry values,Template=Key: , Name: )
    Action 17:07:04: RemoveRegistryValues. Removing system registry values
    MSI (c) (67:97): Executing op: ProgressTotal(Total=1,Type=1,ByteEquivalent=13200)
    MSI (c) (67:97): Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentV ersion\Run,,BinaryType=0)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=Virtual DAEMON,,)
    RemoveRegistryValues: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run, Name: Virtual DAEMON
    MSI (c) (67:97): Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: , Directory: , Size: )
    Action 17:07:04: InstallFiles. Copying new files
    MSI (c) (67:97): Executing op: ProgressTotal(Total=624610,Type=0,ByteEquivalent=1 )
    MSI (c) (67:97): Executing op: SetTargetFolder(Folder=C:\Program Files\D-Tools\Plugins\Images\)
    MSI (c) (67:97): Executing op: SetSourceFolder(Folder=1\PLUGINS\IMAGES\|Plugins\I mages\)
    MSI (c) (67:97): Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=_2740A406AED1B0CC996F5CF323CE6333,By tesPerTick=32768,CopierType=2,ModuleFileName=C:\wi ndows\TEMP\529ea.msi,,,,,IsFirstPhysicalMedia=1)
    MSI (c) (67:97): Executing op: FileCopy(SourceName=CCDMOUNT.DLL|ccdmount.dll,Sour ceCabKey=_05F6F4B02A8D4DA59F8FE1E074DBC461,DestNam e=ccdmount.dll,Attributes=512,FileSize=6656,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=1.2. 0.0,Language=0,InstallMo
    de=126353408,,,,,,)
    MSI (c) (67:97): File: C:\Program Files\D-Tools\Plugins\Images\ccdmount.dll; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_05F6F4B02A8D4DA59F8FE1E074DBC461' is compressed
    InstallFiles: File: ccdmount.dll, Directory: C:\Program Files\D-Tools\Plugins\Images\, Size: 6656
    MSI (c) (67:97): Note: 1: 2318 2: C:\Program Files\D-Tools\Plugins\Images\ccdmount.dll
    MSI (c) (67:97): Executing op: SetTargetFolder(Folder=C:\WINDOWS\SYSTEM\IOSUBSYS\ )
    MSI (c) (67:97): Executing op: SetSourceFolder(Folder=1\SYSTEM~1\IOSUBSYS\|System Folder\IOSUBSYS\)
    MSI (c) (67:97): Executing op: FileCopy(SourceName=STORMPRT.PDR|stormprt.pdr,Sour ceCabKey=_1A9AF1CF76D44CEEB4939794A59A4F54,DestNam e=stormprt.pdr,Attributes=512,FileSize=7108,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,,,InstallMod e=126353408,,,,,,)
    MSI (c) (67:97): File: C:\WINDOWS\SYSTEM\IOSUBSYS\stormprt.pdr; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_1A9AF1CF76D44CEEB4939794A59A4F54' is compressed
    InstallFiles: File: stormprt.pdr, Directory: C:\WINDOWS\SYSTEM\IOSUBSYS\, Size: 7108
    MSI (c) (67:97): Note: 1: 2318 2: C:\WINDOWS\SYSTEM\IOSUBSYS\stormprt.pdr
    MSI (c) (67:97): Executing op: FileCopy(SourceName=MDSMOUNT.DLL|mdsmount.dll,Sour ceCabKey=_23E711B4C2014BEF63E7D32A5BE5F0F0,DestNam e=mdsmount.dll,Attributes=512,FileSize=11264,PerTi ck=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=1.1 .0.0,Language=0,InstallM
    ode=126353408,,,,,,)
    MSI (c) (67:97): File: C:\Program Files\D-Tools\Plugins\Images\mdsmount.dll; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_23E711B4C2014BEF63E7D32A5BE5F0F0' is compressed
    InstallFiles: File: mdsmount.dll, Directory: C:\Program Files\D-Tools\Plugins\Images\, Size: 11264
    MSI (c) (67:97): Note: 1: 2318 2: C:\Program Files\D-Tools\Plugins\Images\mdsmount.dll
    MSI (c) (67:97): Executing op: SetTargetFolder(Folder=C:\Program Files\D-Tools\Icons\)
    MSI (c) (67:97): Executing op: SetSourceFolder(Folder=1\ICONS\|Icons\)
    MSI (c) (67:97): Executing op: FileCopy(SourceName=TRAY1.ICO|tray1.ico,SourceCabK ey=_49261909BC5A4E379F95509D8C69DCC2,DestName=tray 1.ico,Attributes=512,FileSize=318,PerTick=32768,,V erifyMedia=1,,,,,CheckCRC=0,,,InstallMode=12635340 8,,,,,,)
    MSI (c) (67:97): File: C:\Program Files\D-Tools\Icons\tray1.ico; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_49261909BC5A4E379F95509D8C69DCC2' is compressed
    InstallFiles: File: tray1.ico, Directory: C:\Program Files\D-Tools\Icons\, Size: 318
    MSI (c) (67:97): Note: 1: 2318 2: C:\Program Files\D-Tools\Icons\tray1.ico
    MSI (c) (67:97): Executing op: SetTargetFolder(Folder=C:\WINDOWS\)
    MSI (c) (67:97): Executing op: SetSourceFolder(Folder=1\WINDOW~1\|Windows Folder\)
    MSI (c) (67:97): Executing op: FileCopy(SourceName=DAEMON.DLL|daemon.dll,SourceCa bKey=_5B6A3D472008842B045A0ECC20D12C58,DestName=da emon.dll,Attributes=512,FileSize=69120,PerTick=327 68,,VerifyMedia=1,,,,,CheckCRC=0,Version=3.46.0.0, Language=0,InstallMode=1
    26353408,,,,,,)
    MSI (c) (67:97): File: C:\WINDOWS\daemon.dll; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_5B6A3D472008842B045A0ECC20D12C58' is compressed
    InstallFiles: File: daemon.dll, Directory: C:\WINDOWS\, Size: 69120
    MSI (c) (67:97): Note: 1: 2318 2: C:\WINDOWS\daemon.dll
    MSI (c) (67:97): Note: 1: 2360
    MSI (c) (67:97): Executing op: FileCopy(SourceName=PDIMOUNT.DLL|pdimount.dll,Sour ceCabKey=_622411564CD4AE4C6843CC5218F69322,DestNam e=pdimount.dll,Attributes=512,FileSize=7680,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=1.1. 0.0,Language=0,InstallMo
    de=126353408,,,,,,)
    MSI (c) (67:97): File: C:\Program Files\D-Tools\Plugins\Images\pdimount.dll; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_622411564CD4AE4C6843CC5218F69322' is compressed
    InstallFiles: File: pdimount.dll, Directory: C:\Program Files\D-Tools\Plugins\Images\, Size: 7680
    MSI (c) (67:97): Note: 1: 2318 2: C:\Program Files\D-Tools\Plugins\Images\pdimount.dll
    MSI (c) (67:97): Executing op: FileCopy(SourceName=NRGMOUNT.DLL|nrgmount.dll,Sour ceCabKey=_6728973B34FE42F3E90D17B2EC4709FB,DestNam e=nrgmount.dll,Attributes=512,FileSize=12288,PerTi ck=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=1.2 .0.0,Language=0,InstallM
    MSI (c) (67:97): File: C:\Program Files\D-Tools\Plugins\Images\nrgmount.dll; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_6728973B34FE42F3E90D17B2EC4709FB' is compressed
    InstallFiles: File: nrgmount.dll, Directory: C:\Program Files\D-Tools\Plugins\Images\, Size: 12288
    MSI (c) (67:97): Note: 1: 2318 2: C:\Program Files\D-Tools\Plugins\Images\nrgmount.dll
    MSI (c) (67:97): Executing op: SetTargetFolder(Folder=C:\WINDOWS\SYSTEM32\Drivers \)
    MSI (c) (67:97): Executing op: SetSourceFolder(Folder=1\WINDOW~1\SYSTEM32\DRIVERS \|Windows Folder\SYSTEM32\Drivers\)
    MSI (c) (67:97): Executing op: FileCopy(SourceName=STORMBUS.SYS|stormbus.sys,Sour ceCabKey=_A7BDB994C34D418D88EFFA78D86ED008,DestNam e=stormbus.sys,Attributes=512,FileSize=156800,PerT ick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=3. 46.0.0,Language=0,Instal
    lMode=126353408,,,,,,)
    MSI (c) (67:97): File: C:\WINDOWS\SYSTEM32\Drivers\stormbus.sys; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_A7BDB994C34D418D88EFFA78D86ED008' is compressed
    InstallFiles: File: stormbus.sys, Directory: C:\WINDOWS\SYSTEM32\Drivers\, Size: 156800
    MSI (c) (67:97): Note: 1: 2318 2: C:\WINDOWS\SYSTEM32\Drivers\stormbus.sys
    MSI (c) (67:97): Executing op: FileCopy(SourceName=BW5MOUNT.DLL|bw5mount.dll,Sour ceCabKey=_A9FE412ECDC542C189F46DC3A07DE664,DestNam e=bw5mount.dll,Attributes=512,FileSize=7168,PerTic k=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=1.0. 2.0,Language=0,InstallMo
    de=126353408,,,,,,)
    MSI (c) (67:97): File: C:\Program Files\D-Tools\Plugins\Images\bw5mount.dll; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_A9FE412ECDC542C189F46DC3A07DE664' is compressed
    InstallFiles: File: bw5mount.dll, Directory: C:\Program Files\D-Tools\Plugins\Images\, Size: 7168
    MSI (c) (67:97): Note: 1: 2318 2: C:\Program Files\D-Tools\Plugins\Images\bw5mount.dll
    MSI (c) (67:97): Executing op: SetTargetFolder(Folder=C:\Program Files\D-Tools\)
    MSI (c) (67:97): Executing op: SetSourceFolder(Folder=1\)
    MSI (c) (67:97): Executing op: FileCopy(SourceName=PFCTOC.DLL|pfctoc.dll,SourceCa bKey=_AB1F207C755D41E481F0CF3E6FFE7B74,DestName=pf ctoc.dll,Attributes=512,FileSize=167936,PerTick=32 768,,VerifyMedia=1,,,,,CheckCRC=0,Version=1.0.0.12 ,Language=1033,InstallMo
    de=126353408,,,,,,)
    MSI (c) (67:97): File: C:\Program Files\D-Tools\pfctoc.dll; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_AB1F207C755D41E481F0CF3E6FFE7B74' is compressed
    InstallFiles: File: pfctoc.dll, Directory: C:\Program Files\D-Tools\, Size: 167936
    MSI (c) (67:97): Note: 1: 2318 2: C:\Program Files\D-Tools\pfctoc.dll
    MSI (c) (67:97): Executing op: FileCopy(SourceName=DAEMON.EXE|daemon.exe,SourceCa bKey=_AD1BBC6C97136594B89931DE25DC2BA1,DestName=da emon.exe,Attributes=512,FileSize=81920,PerTick=327 68,,VerifyMedia=1,,,,,CheckCRC=0,Version=3.46.0.0, Language=0,InstallMode=1
    26353408,,,,,,)
    MSI (c) (67:97): File: C:\Program Files\D-Tools\daemon.exe; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_AD1BBC6C97136594B89931DE25DC2BA1' is compressed
    InstallFiles: File: daemon.exe, Directory: C:\Program Files\D-Tools\, Size: 81920
    MSI (c) (67:97): Note: 1: 2318 2: C:\Program Files\D-Tools\daemon.exe
    MSI (c) (67:97): Executing op: SetTargetFolder(Folder=C:\Program Files\D-Tools\Lang\)
    MSI (c) (67:97): Executing op: SetSourceFolder(Folder=1\LANG\|Lang\)
    MSI (c) (67:97): Executing op: FileCopy(SourceName=1033.DLL|1033.dll,SourceCabKey =_C1427C2E823BA8FD54C6128B345EC95B,DestName=1033.d ll,Attributes=512,FileSize=7360,PerTick=32768,,Ver ifyMedia=1,,,,,CheckCRC=0,Version=3.46.0.0,Languag e=1033,InstallMode=12635
    3408,,,,,,)
    MSI (c) (67:97): File: C:\Program Files\D-Tools\Lang\1033.dll; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_C1427C2E823BA8FD54C6128B345EC95B' is compressed
    InstallFiles: File: 1033.dll, Directory: C:\Program Files\D-Tools\Lang\, Size: 7360
    MSI (c) (67:97): Note: 1: 2318 2: C:\Program Files\D-Tools\Lang\1033.dll
    MSI (c) (67:97): Executing op: FileCopy(SourceName=TRAY2.ICO|tray2.ico,SourceCabK ey=_DFEDEE2798614FF5999E1653431C6EEF,DestName=tray 2.ico,Attributes=512,FileSize=318,PerTick=32768,,V erifyMedia=1,,,,,CheckCRC=0,,,InstallMode=12635340 8,,,,,,)
    MSI (c) (67:97): File: C:\Program Files\D-Tools\Icons\tray2.ico; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_DFEDEE2798614FF5999E1653431C6EEF' is compressed
    InstallFiles: File: tray2.ico, Directory: C:\Program Files\D-Tools\Icons\, Size: 318
    MSI (c) (67:97): Note: 1: 2318 2: C:\Program Files\D-Tools\Icons\tray2.ico
    MSI (c) (67:97): Executing op: SetTargetFolder(Folder=C:\Program Files\D-Tools\Help\)
    MSI (c) (67:97): Executing op: SetSourceFolder(Folder=1\HELP\|Help\)
    MSI (c) (67:97): Executing op: FileCopy(SourceName=1033.CHM|1033.chm,SourceCabKey =_E08399B558BF4C58B85DFF7D3EF4FF54,DestName=1033.c hm,Attributes=512,FileSize=88674,PerTick=32768,,Ve rifyMedia=1,,,,,CheckCRC=0,,,InstallMode=126353408 ,,,,,,)
    MSI (c) (67:97): File: C:\Program Files\D-Tools\Help\1033.chm; To be installed; No patch; No existing file
    MSI (c) (67:97): Source for file '_E08399B558BF4C58B85DFF7D3EF4FF54' is compressed
    InstallFiles: File: 1033.chm, Directory: C:\Program Files\D-Tools\Help\, Size: 88674
    MSI (c) (67:97): Note: 1: 2318 2: C:\Program Files\D-Tools\Help\1033.chm
    MSI (c) (67:97): Executing op: InstallProtectedFiles(AllowUI=1)
    MSI (c) (67:97): Executing op: ActionStart(Name=CreateShortcuts,Description=Creat ing shortcuts,Template=Shortcut: )
    Action 17:07:05: CreateShortcuts. Creating shortcuts
    MSI (c) (67:97): Executing op: SetTargetFolder(Folder=25)
    MSI (c) (67:97): Executing op: ShortcutCreate(Name=DAEMON~1|DAEMON Tools,,,FileName=C:\Program Files\D-Tools\daemon.exe,Arguments=-lang 1033,WorkingDir=C:\Program Files\D-Tools\,,IconIndex=0,,ShowCmd=1,)
    CreateShortcuts: Shortcut: DAEMON~1|DAEMON Tools
    MSI (c) (67:97): Executing op: ActionStart(Name=WriteRegistryValues,Description=W riting system registry values,Template=Key: , Name: , Value: )
    Action 17:07:05: WriteRegistryValues. Writing system registry values
    MSI (c) (67:97): Executing op: RegOpenKey(Root=-2147483646,Key=Software\Microsoft\Windows\CurrentV ersion\Run,,BinaryType=0)
    MSI (c) (67:97): Executing op: RegAddValue(Name=DAEMON Tools-1033,Value="C:\Program Files\D-Tools\daemon.exe" -lang 1033,)
    WriteRegistryValues: Key: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Run, Name: DAEMON Tools-1033, Value: "C:\Program Files\D-Tools\daemon.exe" -lang 1033
    MSI (c) (67:97): Executing op: ActionStart(Name=RegisterProduct,Description=Regis tering product,Template=)
    Action 17:07:05: RegisterProduct. Registering product
    MSI (c) (67:97): Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=_2740A406AED1B0CC996F5CF323CE6333,By tesPerTick=0,CopierType=2,ModuleFileName=C:\window s\TEMP\529ea.msi,,,,,IsFirstPhysicalMedia=1)
    MSI (c) (67:97): Executing op: DatabaseCopy(DatabasePath=C:\windows\TEMP\529ea.ms i,ProductCode={56CA5D3B-3002-4E7B-90FE-071D8FDF3814},CabinetStreams=_2740A406AED1B0CC996F 5CF323CE6333,,)
    MSI (c) (67:97): Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Uninstall\{56CA5D3B-3002-4E7B-90FE-071D8FDF3814} 3: 2
    MSI (c) (67:97): Executing op: ProductRegister(UpgradeCode={25C1F3B4-F317-41F4-AE1C-FBD533DE1253},VersionString=3.46.0,HelpLink=suppor t@daemon-tools.cc,,,InstallSource=C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\,Publisher=DAEMON'S HOME,URLInfoA
    bout=http://www.daemon-tools.cc,,,,,,,Contact=DAEMON'S HOME,,,,EstimatedSize=2818)
    RegisterProduct: {56CA5D3B-3002-4E7B-90FE-071D8FDF3814}
    MSI (c) (67:97): Executing op: ProductCPDisplayInfoRegister()
    MSI (c) (67:97): Executing op: ActionStart(Name=PublishFeatures,Description=Publi shing Product Features,Template=Feature: )
    Action 17:07:05: PublishFeatures. Publishing Product Features
    MSI (c) (67:97): Executing op: FeaturePublish(Feature=DefaultFeature,,Absent=2,Co mponent=j.OTv$)@!Yq.,7dU77Fcu79%-Xa)[EpMglb@KaB9e.NS7~ZXRu-d'F)&~9i63i*`)IO@pHYg88OE{'*T4!?NL*hafOut3i!5raxZm AfVDW{gJgNC*j'^Gt!V$wgnty=KvzIM9I(jtG)U}uX%pa0fUTq ^v`d)^fxo+O'y0T
    lU-_K(@UZa`kW8u7%i+E2X8MqShLTnD[l@h'V{=&+17IhqEe8@MnIq{u@YEUYx[.=HdCmz9OZ`3Oa?nEa(pEdPW3FJ9R'NRL*,tbq6,OCk(?ycF3W E6ZROjopo1Wf%MoLZMwi?wpGqDnm(9t&mi10UNjQ!)
    PublishFeatures: Feature: DefaultFeature
    MSI (c) (67:97): Executing op: ActionStart(Name=PublishProduct,Description=Publis hing product information,)
    Action 17:07:05: PublishProduct. Publishing product information
    MSI (c) (67:97): Executing op: IconCreate(Icon=_daemoncp.exe,Data=BinaryData)
    1: _daemoncp.exe
    MSI (c) (67:97): Executing op: PackageCodePublish(PackageKey={75AC544C-C2F2-45F1-991F-8AC6CF687776})
    MSI (c) (67:97): Executing op: ProductPublish(PackageKey={75AC544C-C2F2-45F1-991F-8AC6CF687776})
    MSI (c) (67:97): Note: 1: 1402 2: UNKNOWN\Installer\Products\B3D5AC652003B7E409EF70D 1F8FD8341 3: 2
    MSI (c) (67:97): Executing op: UpgradeCodePublish(UpgradeCode={25C1F3B4-F317-41F4-AE1C-FBD533DE1253})
    MSI (c) (67:97): Executing op: SourceListPublish(,,,,NumberOfDisks=1)
    MSI (c) (67:97): Note: 1: 1402 2: UNKNOWN\Installer\Products\B3D5AC652003B7E409EF70D 1F8FD8341\SourceList 3: 2
    MSI (c) (67:97): Executing op: ProductPublishClient(,,)
    MSI (c) (67:97): Executing op: SourceListRegisterLastUsed(SourceProduct={56CA5D3B-3002-4E7B-90FE-071D8FDF3814},LastUsedSource=C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\)
    MSI (c) (67:97): Specifed source is already in a list.
    MSI (c) (67:97): Machine policy value 'DisableBrowse' is 0
    MSI (c) (67:97): Machine policy value 'AllowLockdownBrowse' is 0
    MSI (c) (67:97): Set LastUsedSource to: C:\WINDOWS\Downloaded Installations\DAEMON Tools 3.46\.
    MSI (c) (67:97): Set LastUsedType to: n.
    MSI (c) (67:97): Set LastUsedIndex to: 1.
    MSI (c) (67:97): Executing op: ActionStart(Name=DaemonDriverInstall,,)
    Action 17:07:05: DaemonDriverInstall.
    MSI (c) (67:97): Executing op: CustomActionSchedule(Action=DaemonDriverInstall,Ac tionType=3073,Source=BinaryData,Target=_DaemonDriv erInstall@4,CustomActionData=d346bus;d346prt)
    MSI (c) (67:97): Creating MSIHANDLE (4) of type 790536 for thread -3618153
    DEBUG: Error 2835: The control ErrorIcon was not found on dialog ErrorDialog
    The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2835. The arguments are: ErrorIcon, ErrorDialog,
    Error 25001. Device setup error: code 25032 (0x61C8), 0 (0x0) . Contact your support personnel.
    1: Driver install: removing PCI\D346PRT&0&0&0\0000
    1: Driver install: unable to read driver key in registry
    1: Driver install: removing ROOT\D346BUS\0000
    Action ended 17:08:59: InstallFinalize. Return value 3.
    MSI (c) (67:97): Executing op: Header(Signature=1397708873,Version=200,Timestamp= 821659874,LangId=1033,Platform=0,ScriptType=2,Scri ptMajorVersion=21,ScriptMinorVersion=4,ScriptAttri butes=0)
    Action 17:08:59: Rollback. Rolling back action:
    Rollback: DaemonDriverInstall
    Rollback: Publishing product information
    MSI (c) (67:97): Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\Installer\Products \B3D5AC652003B7E409EF70D1F8FD8341\SourceList\Net,, BinaryType=0)
    MSI (c) (67:97): Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\Installer\Products \B3D5AC652003B7E409EF70D1F8FD8341\SourceList,,Bina ryType=0)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=LastUsedSource,Value=#%n;1;C:\ WINDOWS\Downloaded Installations\DAEMON Tools 3.46\,)
    MSI (c) (67:97): Executing op: RegCreateKey()
    MSI (c) (67:97): Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\Installer\Products \B3D5AC652003B7E409EF70D1F8FD8341,,BinaryType=0)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=Clients,Value=
    MSI (c) (67:97): Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\Installer\Products \B3D5AC652003B7E409EF70D1F8FD8341\SourceList\Media ,,BinaryType=0)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=1,Value=;,)
    MSI (c) (67:97): Executing op: RegRemoveKey()
    MSI (c) (67:97): Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Classes\Installer\Prod ucts\B3D5AC652003B7E409EF70D1F8FD8341\SourceList\M edia 3: 2
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=1,Value=#%C:\WINDOWS\Downloade d Installations\DAEMON Tools 3.46\,)
    MSI (c) (67:97): Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Classes\Installer\Prod ucts\B3D5AC652003B7E409EF70D1F8FD8341\SourceList\N et 3: 2
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=PackageName,Value=daemon.msi,)
    MSI (c) (67:97): Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Classes\Installer\Prod ucts\B3D5AC652003B7E409EF70D1F8FD8341\SourceList 3: 2
    MSI (c) (67:97): Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\Installer\UpgradeC odes\4B3F1C52713F4F14EAC1BF5D33ED2135,,BinaryType= 0)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=B3D5AC652003B7E409EF70D1F8FD83 41,,)
    MSI (c) (67:97): Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Classes\Installer\Upgr adeCodes\4B3F1C52713F4F14EAC1BF5D33ED2135 3: 2
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=ProductIcon,Value=C:\WINDOWS\I nstaller\{56CA5D3B-3002-4E7B-90FE-071D8FDF3814}\_daemoncp.exe,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=AdvertiseFlags,Value=#388,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=Assignment,Value=#1,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=Version,Value=#53346304,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=Language,Value=#1033,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=PackageCode,Value=C445CA572F2C 1F5499F1A86CFC867767,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=ProductName,Value=DAEMON Tools,)
    MSI (c) (67:97): Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Classes\Installer\Prod ucts\B3D5AC652003B7E409EF70D1F8FD8341 3: 2
    MSI (c) (67:97): Executing op: RegAddValue(Name=PackageCode,Value=C445CA572F2C1F5 499F1A86CFC867767,)
    MSI (c) (67:97): Executing op: FileRemove(,FileName=C:\WINDOWS\Installer\{56CA5D3 B-3002-4E7B-90FE-071D8FDF3814}\_daemoncp.exe,Elevate=1,)
    Rollback: Publishing Product Features
    MSI (c) (67:97): Executing op: RegOpenKey(Root=-2147483646,Key=Software\Microsoft\Windows\CurrentV ersion\Installer\Features\B3D5AC652003B7E409EF70D1 F8FD8341,,BinaryType=0)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=DefaultFeature,Value=j.OTv$)@! Yq.,7dU77Fcu79%-Xa)[EpMglb@KaB9e.NS7~ZXRu-d'F)&~9i63i*`)IO@pHYg88OE{'*T4!?NL*hafOut3i!5raxZm AfVDW{gJgNC*j'^Gt!V$wgnty=KvzIM9I(jtG)U}uX%pa0fUTq ^v`d)^fxo+O'y0TlU-_K(@UZa`kW8u7%
    i+E2X8MqShLTnD[l@h'V{=&+17IhqEe8@MnIq{u@YEUYx[.=HdCmz9OZ`3Oa?nEa(pEdPW3FJ9R'NRL*,tbq6,OCk(?ycF3W E6ZROjopo1Wf%MoLZMwi?wpGqDnm(9t&mi10UNjQ!,)
    MSI (c) (67:97): Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Installer\Features\B3D5AC652003B7E409EF 70D1F8FD8341 3: 2
    MSI (c) (67:97): Executing op: RegOpenKey(Root=-2147483646,Key=Software\Classes\Installer\Features \B3D5AC652003B7E409EF70D1F8FD8341,,BinaryType=0)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=DefaultFeature,,)
    MSI (c) (67:97): Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Classes\Installer\Feat ures\B3D5AC652003B7E409EF70D1F8FD8341 3: 2
    Rollback: Registering product
    MSI (c) (67:97): Executing op: RegOpenKey(Root=-2147483646,Key=Software\Microsoft\Windows\CurrentV ersion\Uninstall\{56CA5D3B-3002-4E7B-90FE-071D8FDF3814},,BinaryType=0)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=DisplayName,Value=DAEMON Tools,)
    MSI (c) (67:97): Executing op: RegOpenKey(Root=-2147483646,Key=Software\Microsoft\Windows\CurrentV ersion\Installer\Products\B3D5AC652003B7E409EF70D1 F8FD8341,,BinaryType=0)
    MSI (c) (67:97): Executing op: RegOpenKey(Root=-2147483646,Key=Software\Microsoft\Windows\CurrentV ersion\Installer\UpgradeCodes\4B3F1C52713F4F14EAC1 BF5D33ED2135,,BinaryType=0)
    MSI (c) (67:97): Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Installer\UpgradeCodes\4B3F1C52713F4F14 EAC1BF5D33ED2135 3: 2
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=WindowsInstaller,Value=#1,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=VersionMinor,Value=#46,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=VersionMajor,Value=#3,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=URLUpdateInfo,,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=URLInfoAbout,Value=http://www.daemon-tools.cc,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=UninstallString,Value=#%MsiExe c.exe /I{56CA5D3B-3002-4E7B-90FE-071D8FDF3814},)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=EstimatedSize,Value=#+2818,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=Size,,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=Readme,,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=Publisher,Value=DAEMON'S HOME,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=ModifyPath,Value=#%MsiExec.exe /I{56CA5D3B-3002-4E7B-90FE-071D8FDF3814},)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=InstallSource,Value=C:\WINDOWS \Downloaded Installations\DAEMON Tools 3.46\,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=InstallLocation,,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=InstallDate,Value=20040725,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=HelpTelephone,,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=HelpLink,Value=#%support@daemo n-tools.cc,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=DisplayVersion,Value=3.46.0,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=Contact,Value=DAEMON'S HOME,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=Comments,,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=AuthorizedCDFPrefix,,)
    MSI (c) (67:97): Executing op: RegRemoveValue(Name=LocalPackage,Value=C:\WINDOWS\ Installer\529ee.msi,)
    reread my forum post and noticed that the entire log was not pressent.. please im me on my msn account to get full log..
      I did that registery clean thing found 1,804 errors .. cleaned them and fixed.. restarted computer redownloaded softwear.. still gave me the same error.. please inform me what to do next
        i can't find that resitery cleaner program again.. please link.. also any idea's on what went wrong? i still waiting.. i can e-mail you the log if you wish.. i just need e-mail addy.. waiting.. for your reply..
          found nasty spy bot on my computer removed.. and still can not install.. am at a loss.. have no idea why your program will not install.. also have logged this attempt to install. please e-mail me or respond some how.. as im getting alittle frusterated with your lack of custumer suport..
          :evil: i will be more then happy to a) send you copy of log via e-mail
          b) send you copy of log via msn or aim messenger
          c) follow your advice as how to resolve this issue on my computer so as to be able to run your softwear..
          but im getting sick of not hearing any responces to my questions.. if needed i can also upload the log for a short time onto my msn group web page.. and post a link for you to look at it.. i realize you guys are very busy and have lives of your own. and can not repond to every cry for help as proptly as you would like. but i also see that you have posted replys on other issues and only taken a cursery glance at mine..
          please respond to this.. as it is my last attempt to resolve this issue before i give up.. . thanks for your time..
            Dear Sir,
            please use : support@daemon-tools.cc
            to contact us!
            Also please give us information when you purchased our software
            Thank you
              Before running setup please go to device manager and clean all unknown devices then reboot.
              When running setup you should also see "Building driver info..." message box on 9x system. Do you see that?
                yes it completes the install of the driver and after that it freezes.
                  That's another story then - setup seems ok now and system frezes when driver is running. Some other compatibility problem then...
                    I can post a complete list of running programs and all the programs i have on my computer if you want...
                    • #11
                      The problem is most likely some driver that may remain even from some software that you have removed or some protection driver. So complete list is unlikely to help. But as first step you can try remove other burning and antivirus sofware to check.
                      • #12
                        i have discovered the problem to be a major system bug, have been unable to uninstall or install programs for awhile now.. will try again when i fix this issue.
