Page 5 of 6 FirstFirst ... 3456 LastLast
Showing results 41 to 50 of 54
Thread: 64-Bit Driver
  1. #41
    ** Wanders in and sits down quietly in a corner to wait paiently for as long as it takes **
  2. #42
    Just a quick question.
    Does this mean that you will release the 32bit V4 and then a 64bit V4, or both will be in the same release?
    I'm just wondering. Thanks for your time and efforts boys, keep up the good work!
  3. #43
    Default Just another 'attaboy'
    Hey, I've been using Daemon-Tools since sometime in the 1.xx (I still have a copy of each release since 2.41 (sadly a drive failure ate the older ones). Anyway, I just wanted to say thank you for producing a great product. Keep it up! I just moved to an athlon 64, and I can't wait to get DT up and running on it!
  4. #44
    06.08.2005
    1
    Default In-the-mean-time suggestion
    I too am running an AMD 64 and have made the leap to XP64. To get around the lack of d-tools I simply shared the virtual drive from another machine on my network and install images from it..it takes a little longer and I'd rather have it on my system but it is a fine workaround until the 4 is released. Just thought I'd share in case anyone that is being held-back by this hadn't thought of it.
  5. #45
    Default Re: In-the-mean-time suggestion
    Quote Originally Posted by ianai
    I simply shared the virtual drive from another machine on my network and install images from it..Just thought I'd share in case anyone that is being held-back by this hadn't thought of it.
    Ohhhhh I hadn't thought of doing something like that.. thank you for posting that tip, much appreciated
  6. #46
    Why not add to the fun? It is August after all and it seems many people have been waiting for months, so here's a bump for everyone else. I've been using daemon tools for quite a long time, and it wasn't until years into the whole thing that I even needed to register for the forums. I'm hoping you'll at least drop a hint on when v4 will be available to the public? Thanks for all the great work over the years.
    Danke schöne!
  7. #47
    I've just tried Fantom DVD (just google for it -- it's the first alternative virtual image mount that I've found since daemon tool doesn't work under 64-bit windows). It works great under windows x64. It's not as user-friendly like daemon tools. But here's something to hold everyone over until we get a version of daemon tools that works under x64.
  8. #48
    Fantom DVD can't mount most MDS/MDF files (even tho it supposedly has a plugin for it) so for now there is no way for me to mount those kinds of images until DT v4 is released
  9. #49
    If Fantom DVD doesn't appear to support the image format, change the file extension to one it does support, such as .iso. Worked for me, only tried it once so far though.
  10. #50
    hi all,
    when do we get the new version with x64-support ?
    best regards,
    willi
