Page 2 of 2 FirstFirst 12
Showing results 11 to 15 of 15
Thread: Potential Downloader Virus Inside DTLite Installer
    BEWARE: Daemon Tools Lite is still at it, still infected with malware/adware. Do not use the "free" version of this software. Given the nasty results of installing the free version, I suggest do not license and use the paid version either. Pass the word, avoid Daemon Tools software.
    Here are the detected malware symptoms according to McAfee VirusScan:
    9/28/2015 2:47:16 PM Deleted DOMAINAC\userg C:\Users\userg\AppData\Local\Temp\DTLite1010-0074.exe C:\Program Files\DAEMON Tools Lite\OC1.exe RDN/Generic PUP.x!cxx (Potentially Unwanted Program)
    9/28/2015 3:12:41 PM Deleted DOMAINAC\userg C:\Users\userg\AppData\Local\Temp\DAEMON Tools Lite.exe C:\Program Files\DAEMON Tools Lite\OC1.exe RDN/Generic PUP.x!cxx (Potentially Unwanted Program)
    Customer Terramex's Avatar
    06.09.2004
    2,566
    The OC1.exe is responsible for downloading the actual Adware/PUP programs during setup.
    If you don't confide that unticking the adware is working properly, i already told you that you won't get any 3rd party recommendation if you disconnect the internet connection.
    Or you can make a silent installation in the command line with the /S switch (upper-case S !)
    In version 10 you have to go to %userprofile%\ AppData\Local\Temp after running the small DTLiteInstaller.exe, and copy the complete DAEMON Tools Lite.exe installer to your desktop or wherever.
    my avira is running amok with the latets installer.
    DTLite1020-0114_paid.exe
    i get a warning about adware "amonetizer".
    can´t copy or install that /%%$& without disabling my antivirus.
    i PAID for this so why are bothered with this crap???
    My norton keeps removing it before I can install it! How do I fix that?
    Administrator
    SUPPORT1's Avatar
    07.02.2012
    373
    Does your post relate to the DAEMON Tools software? If so, please specify more details.
    Thank you in advance.
    Don't worry! Be Happy!
