Page 1 of 3 123 LastLast
Showing results 1 to 10 of 24
Thread: Problems with 48x burning
    Default Problems with 48x burning
    Hey...
    I'm having problems lately with burning CDs with 48x speed. Both DiscJuggler and Alcohol 120% will always suffer from an empty buffer and pause burning (burn-proof);
    and then either continue with max speed or sometimes with only 24x.
    Can anyone confirm these problems? It can definitely not be my hardware as I haven't changed anything lately and I was able to perfectly burn with max speed (48x) from the first to the last sector some time ago...
    Now I get buffer underruns over and over when trying to copy on-the-fly, and sometimes during the burning process from HDD. If not when burning from HDD, DiscJuggler will always have problems when finishing the disc - while finishing it will pause burning like when it has a buffer underrun.
    My system specs:
    AMD Athlon XP 1800+
    ASUS A7V333 (VIA KT333)
    512MB RAM 266MHz
    Seagate ST380021A (80GB 7200rpm) primary master
    Toshiba SD-M1612 secondary master
    Lite-On LTR48125W secondary slave
    Windows XP Pro SP1
    VIA Hyperion 4in1 v4.45v (all DMA enabled)
    No firewall/antivirus installed
    Hope I haven't forgotten anything...
    Sergei
    Check if you have MS Office installed, if the idiotic indexing option fucks up your writing ...
    also check the media you are using ... SMART-BURN will lower the write speed with buffer-underrun-symptoms (yellow LED) in case of bad media ...
    Nope
    indexing is the very first thing I kick outta autorun after having installed Office, but I don't have it installed anyway
    concerning media:
    TDK Speed-X CD-R80 48x, TDK's so-called "reference CD-R" (0,69)
    Octron 700MB 40x speed (bought at LIDL in germany, 0,39)
    all the same
    Which firmware do you use for the 48125W?
    Do you also get buffer-underruns-symptoms while write simulation/test?
  5. #5
    firmware vs08
    haven't tried simulating, I'll check it out after a dog-walk
  6. #6
    I tried simulating an on-the-fly-copy of WarCraft III, still got pauses during the burning process - although the Memory Buffer Usage in Alcohol was at >90% at all times, CPU usage <15%...
  7. #7
    Try to disable the Hyperion-Via-Drivers and use default drivers instead (and enable DMA there, too, of course)
  8. #8
    by the way...
    I installed DirectX 9, is it possible that this causes problems too? Does anyone already know?
    Sorry, I only just remembered, didn't think of it before...
  9. #9
    New Windows XP installation, no Direct X 9, VIA 4in1 v4.43v, same problem. When trying to burn an Aquanox 2 image Alcohol (1.4.0) paused burning when it had reached about 25x, then continued with 20x until the disc was finished. This SUCKS. :evil: I have not bought a fast computer and a 48x burner and 48x media to burn with 20x.
    Sergei
    P.S.: I've made a screenshot of the Performance Graphic (slightly manipulated);
    you can have a look at it here (~36kb). The CPU usage being at 100% is caused by a running SETI@home client I shut down then.
  10. #10
    Strange ... looks like SMART-BURN thinks bad media detected and reduces write speed ... you have DMA enabled?
