Page 2 of 2 FirstFirst 12
Showing results 11 to 17 of 17
Thread: help needed with burning process
    18.10.2004
    10
    So i heard you can use dvdshrink to compress it, now how does that process work? since i have the iso file already.
    That's not recommended, you'll face extreme quality loss!
    18.10.2004
    10
    so what options do i have? but lets say i did use dvd shrink as my last resort, how does the iso file fit into it if you know
    Depends on the DVD writer you own - if it's dual layer writer, and you're ok with dual layer media prices, you can just use DVD+R DL - otherwise it depends on your acceptance of the quality loss. If you shrink 7.5GB to 4.37GB it'll be a huge difference.
    18.10.2004
    10
    i just have a single layer burner, i'm not spending more on a dual layer, but my question is once i compress it what do i do with it. like is it already in an iso file for me to burn or do i have to do something else?
    as soon as you compressed it with one of the so-called one.click.tools (like
    DVDShrink), you can write back the .iso with f.e. DVD Decrypter or Alcohol120%
    18.10.2004
    10
    ah cool, thanks a bunch.
